Hi all,
I have bought another Connie. She is a 2006 model with only 18,000 miles on her. She is mint condition. Lovely.
I bought her as a non runner. The PO had left her unused for a couple of years.
I removed the carbs and did a full strip down and full clean.
I changed the plugs, and generally serviced her.
It was very difficult to get her to start. When I did get it running it did not like coming off choke. Will not rev below 3000 RPM.
I ran her several times up to temp, and did get her to idle once at 1100 RPM. As soon as you rev it from idle it picks up ok but when you let go of the throttle she either revs at 4-5,000, or stalls.
I noticed the clock will not stay on when you turn the ignition off. I traced this to the black and white wire at the Jbox having no power. Could this be an issue with the running. I have not checked the valves. Could this be an issue.
My problem is that because the bike was bought as a non runner I do not know if it had the problem before and it may have been the reason why the bike was laid up for two years.
I want to get it running nice so that I am ready to ride it once the weather clears.
Hope you folks can fire some thoughts over to me. I am a little miffed at the moment as I thought it would have all been done over this holiday, and I was hoping to be dreaming of the rides to come.
Now I'm thinking of ways to get rid of the thing.
Happy christmas to you all.
