Author Topic: radial pump master cylinder zg1000  (Read 1716 times)
Offline concours80860
« on: October 31, 2012, 05:51:08 PM »
Has anyone done a radial master cylinder? Hate to ask but no results on search.
Re: radial pump master cylinder zg1000
« Reply #1 on: October 31, 2012, 06:58:02 PM »
Do you mean a master cylinder as used on bikes that have radial mount calipers? I might be wrong but I don't think there is anything revolutionarily different in these master cylinders. I run an entire ZRX front end including their 6 piston calipers and use the master cylinder from a much smaller bike (EX500) as it has a 2 mm smaller diameter piston which was tested to deliver a higher pressure but with less volume to which it produces a very powerful brake that is still highly controllable and feathery when first applied.
Offline rwulf
« Reply #2 on: November 01, 2012, 03:31:09 PM »
Read the November issue of Motorcycle Consumer News and you can
answer your own question.
