Author Topic: Handlebar Diameter Question For Cruise Control  (Read 7768 times)
Offline Burbs
  • 2009 ABS
« on: July 24, 2011, 09:43:17 AM »
I am going to be ordering this little cruise control setup from Aerostich http://www.aerostich.com/a-to-b-utilities/rider-comfort/cruise-controls/universal-vista-cruise-control.html It's giving me a choice for a 7/8 or 1" diameter bar and I'm pretty sure it's 7/8 but wanted to double check with you guys here. I believe the area on the handlebar to mount different farkles is 7/8" no?
Thanks,
-Chris
**Fixed the link**
« Last Edit: July 25, 2011, 05:40:39 AM by Burbs »
Offline philipintexas
    • Phils Farkels
Re: Handlebar Diameter Question For Cruise Control
« Reply #1 on: July 24, 2011, 01:06:14 PM »
You're correct, they are 7/8".
« Reply #2 on: July 24, 2011, 03:45:58 PM »
I am going to be ordering this little cruise control setup from Aerostich http://www.aerostich.com/a-to-b-utilities/rider-comfort/cruise-controls/universal-vista-cruise-control.html. It's giving me a choice for a 7/8 or 1" diameter bar and I'm pretty sure it's 7/8 but wanted to double check with you guys here. I believe the area on the handlebar to mount different farkles is 7/8" no?
Not to be overly picky, but that is not a "cruise control" and shouldn't be called such... it is a throttle lock.  Also, your link is broken.
I bought a Vista and tried to install it and it doesn't fit AT ALL on a 2010/2011- it is much too wide.  I looked at the pictures from other people doing it and don't see how it is possible.  So it sits in a box.
http://www.zggtr.org/index.php?topic=352
http://www.zggtr.org/index.php?topic=340
http://www.zggtr.org/index.php?topic=1098
http://www.zggtr.org/index.php?topic=1811
http://www.zggtr.org/index.php?topic=1561
    • Phils Farkels
« Reply #3 on: July 25, 2011, 09:20:49 AM »
Here are a few photos of my VISTA CRUISE installation. I cut off the tab that is formed at a right angle on the bottom. I drilled & tapped holes for two #2 screws, and attached it to the throttle cable housing. I used a disk sander and slightly reduced the material from the inside end of the grip to allow more room.  The brass knob is one I made.
« Reply #4 on: July 25, 2011, 04:29:34 PM »
And for an older 2008/2009 (which I believe is pictured), that might work.  But I did not see how it was possible on the 2010/2011.  The thickness of the nylon simply does not fit in the gap... it is not even remotely close... even discounting the complexity of dealing with the heated grip flange/wiring.  I am not sure what you mean by "reduced the material from the inside end of the grip" but if that would mean bringing a sander near to and attempting to alter my brand new 2011, it simply is not an option.
I hate that I gave up, because I really need and want a throttle lock and I am not/was not pleased with the design or price of the bar-weight-end types.  Alas, I might have to break down and get one.  Damnit, Kawasaki, why didn't you offer a REAL cruise control option??!??!!!
Offline Stavee
« Reply #5 on: July 25, 2011, 06:09:50 PM »
One  size fits all!  Caterpillar  8M4991
« Last Edit: July 25, 2011, 06:45:53 PM by Stavee »
First bike '38 DKW
Offline Burbs
  • 2009 ABS
« Reply #6 on: July 25, 2011, 07:53:35 PM »
WOW! That's a lot more involved than I would have liked.
Offline Burbs
  • 2009 ABS
« Reply #7 on: July 25, 2011, 08:36:44 PM »
I just ordered the Go Cruise and think that will help out. I'm not looking to spend a fortune, I'm just looking for something to take the edge off every so often.
-Chris
Offline mkorn
« Reply #8 on: July 26, 2011, 11:16:08 AM »
-Chris
The Go-Cruise works great for that ... i use mine regularly on long trips.
its nice to be able to take your right hand off the bars to adjsut things or just to relax for a few minutes.
2009 C14 ABS
2002 750 Nighthawk (sold)
2006 DRz 400s
