Author Topic: spline lubrication  (Read 7637 times)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: spline lubrication
« Reply #20 on: August 16, 2012, 11:38:01 AM »
chip, did you check to be sure the oring at the rear of the shaft was intact? they're often cut - Steve
Offline Summit670
« Reply #21 on: August 16, 2012, 12:25:25 PM »
I'm getting into foggy territory here, but I believe in addition to the splines on the hub, you also should pull the snap ring off and disassemble and lube some of the bushings inside.  It's been a few years since I've done it but I found the lube that was in there to be pretty dry and glad I pulled it apart.  This is on the wheel.
Arctic Cat M8 163 rules
Offline ChipP
« Reply #22 on: August 17, 2012, 11:11:27 AM »
Thanks for the heads up Steve. I did take a look since you had mentioned it earlier in this thread. Luckily mine was ok. I did order a spare to have on hand though.
