Author Topic: Better lighting at a low cost? Possible?  (Read 21586 times)
Offline sas mayhem
Re: Better lighting at a low cost? Possible?
« Reply #60 on: October 25, 2011, 02:20:39 PM »
I did decide to sacrifice my right fairing pocket for the controller/ballast/module after looking around under the fairing for places to attach it all.
Rick.
I have the same set up, if you go under the left pocket and, you can use the stud that holds the left side reflector on, that's what I did to mount the ballast.
Cheers
Ron
09 Connie
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« Reply #61 on: October 25, 2011, 02:44:11 PM »
Offline redbarber
  • '09 ABS (wife on '08 Can-AM Spyder follows)
« Reply #62 on: October 29, 2011, 09:35:40 PM »
Grrrrrrr!  Mine still haven't come in.  REALLY wanted to mount them up this weekend.   :'(
If you take yourself too seriously, nobody else will.  Humor is all around you, make it your quest to find all of it!
Offline Uglydog56
« Reply #63 on: December 09, 2011, 02:34:43 PM »
Just a follow up on cheap HID lights for those who want info - Last night I left my bike out for some reason.  This morning it was cold enough I had to scrape frost off the seat.  My headlight had the initial flash but wouldn't stay on only about a second.  I rode to work just using my driving lights.  The sun came out and at lunch time it would fire off again. Food for thought for the minnesotans etc amongst us.  Mine is VVME 50w 4300K car kit with one side removed out of the harness.  I have ran it since March 2011.
Rick A. Cone
COG #9186
98 Connie, 76 CB400F
Offline timsatx
« Reply #64 on: December 10, 2011, 07:55:45 AM »
Mine does this sorta regularly. I am informed that it may be a ground connection. Did you try turning the bike off and the restart it? If not give that a try next time, but turn it off with the key as that resets the circuit. If you just use the handlebar switch it won't work.
Offline Uglydog56
« Reply #65 on: July 19, 2012, 11:28:11 AM »
Follow up:  I had to replace the bulb today as sometime last week it exploded?  I don't think I got rainwater in it, as I still have the seal on the back.  Still running original ballast.  My kit was a 55w bi-xenon VVME car kit with one side removed.
Tim - I did the restart thing and it worked.  And I cleaned my grounds.
Rick A. Cone
COG #9186
