Author Topic: aftermarket seat  (Read 6175 times)
Offline fred-houston
Re: aftermarket seat
« Reply #20 on: March 26, 2012, 05:13:09 AM »
Below picture is a Russell Seat on a C-10.
2001 BMW R1150GS
1999 C-10 (Semi Naked) EFI
Offline Ron Dawg
  • a/k/a ron203
« Reply #21 on: March 26, 2012, 08:55:31 PM »
6'5"  250# and liking my new Corbin. I was crushing my 2000 OEM seat all the way to the pan. The Corbin feels like a hard horse saddle to me. Good for up to 3 hours (so far) and I'm still in the break in period.
2014 C-14 Red
Offline timsatx
« Reply #22 on: March 27, 2012, 06:23:18 AM »
Nice looking seat, but do you really get to use the backrest? I know that even if I scoot up on my seat there is no way I would ever be able to lean back to use it.
« Reply #23 on: March 28, 2012, 12:11:52 AM »
Use it every time I ride.  I guess you can not see it in the picture, but I do not have stock bars.  I have GL1200 bars which allow me to sit completely upright.  Also being 6'5" helps a bit to.
2001 BMW R1150GS
Offline timsatx
« Reply #24 on: March 28, 2012, 07:31:37 AM »
Can you show better pics of the bars? What year are the bars and what did you have to do to attach them?
« Reply #25 on: March 28, 2012, 07:54:37 AM »
The bars are from a GoldWing GL1200.  I got them used off of Ebay.  There are a number of 7/8" bars out there, you just have to find the one that you like.  Be careful of the Goldwing bars, some of them are 7/8" at the grip, but the base is one inch.  I had to mill out my adapter a bit to make mine fit.
The adapter for mine I purchased used off this forum.  They come up for sale every now and then.  Some are Heli Bar adapters and others are manufactured by individuals or companies.  I think Murphs sells them.
Because I went so extreme, I did have to lengthen the clutch, brake and choke cables.  They were purchased from Murph.  I was able to reroute the throttle cable to make it work.
It turned out to be a bigger and more expensive job than I expected, but the end result was worth it.
2001 BMW R1150GS
Offline timsatx
« Reply #26 on: March 28, 2012, 09:56:59 AM »
Sweet, thanks.
Offline bolling
« Reply #27 on: April 07, 2012, 06:06:11 PM »
OP says 6ft 200lbs
What don't you like about your daylong? I have one being built on the 12th of this month. If I knew you had one for sale I would have inquired about it. I am close to your size so that wouldn't be a problem.
