Rear lower bolt. 10mm x 215mm.
I guess congratulations isn't exactly what you're looking for then
If you haven't already, check the other ones too. Most reports I've seen for the rear one breaking was due to corrosion weakening it first, but if the others are messed up it could overload it too.
I don't believe there's an easy replacement for it other than through the dealer, salvage yard or eBay. Murph (murphskits.com) looked for some years ago, and while the fronts are easy to find something compatible, there rears aren't. At least not for a reasonable price.
If you're around Austin (profile sez Ohio, but maybe you're taking a trip soon?), I've got both rear bolts and nuts from a box of fasteners I got from eBay. They look ok, but it's probably not worth the shipping. Up to you. PM me if you're interested and we'll work out the details.
