Author Topic: Ultrasonic cleaning - great for Carbs and other stuff too!  (Read 4641 times)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« on: December 03, 2011, 08:19:21 AM »
 Not inexpensive, but wow does it work! 25L tank can hold lots of hard to clean stuff. here's a couple before / after pics of things things I've done with it - Steve
Re: Ultrasonic cleaning - great for Carbs and other stuff too!
« Reply #1 on: December 03, 2011, 08:24:05 AM »
 I figured since it did such a good job with carbs, I'd try it on some other "hard to clean" items around the house. Here's one it worked good on, but I noticed it sounded different while operating. I'll have to figure out why  :o ... Steve
Offline Motor Head
  • Resurected Concours, $260 Purchase & Counting
« Reply #2 on: December 03, 2011, 08:59:01 AM »
 That's looking very nice there. Way better to get rid of the EPA target chemicals around the workshop these days. The Days of Carb Cleaner baths are coming to an end. But I still see some version of the chemical for sale, Even Walmart carries a small gallon tin.
 Have you gone to the Hot Water washer for cleaning larger Items? These are absolutely fantastic, and what a labor saver as opposed to cleaning by hand in a sink of stink.  ;)
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #3 on: December 03, 2011, 09:20:24 AM »
 Yes, I have a very large Jet - spray cabinet for doing engines and transmissions, tumblers, pressure washers, etc. Cleaning is and has always been a pita and very time consuming. The simple fact is that I catch tons of problems with the parts I'm cleaning during the cleaning processes, and for that alone diligent cleaning is a must.  Ultrasonic is really impressive - I had a smaller unit I used for years for fuel injectors, etc. It was so strong it would remove all the rust too. I learned to be careful with ultrasonic cleaning, parts are so clean they'll sieze or rust almost immediately upon removal from the tank unless addressed with some lubricant. Fortunately, cats are self-lubricating  :yikes: Steve
Offline Motor Head
« Reply #4 on: December 03, 2011, 09:30:26 AM »
 There's been a few guys who have taken the protective coating off of the Mikuni slides also, to much chemical in the Ultra. Ruins the slide quick. I haven't seen anyone go to get another coating on one though. They always opt for either a new one or good used.
 Once you use these modern parts cleaners there is no going back to the Stone Age.
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #5 on: December 03, 2011, 09:43:42 AM »
 That's a good point, and why I've been experimenting with various cleaners, dilution, and temperature in the tank. I want the minimum nessessary. I learned a looong time ago about using the wrong or to much chemical for the job when I soaked a set of 396 heads in muriatic acid... that was an expensive but unforgetable lesson! steve
Offline Motor Head
« Reply #6 on: December 03, 2011, 09:48:01 AM »
 Years ago one of the youngsters took a Binks Spray Gun, and put it in the Chemical dip overnight on a wire. When he checked the next day, there was only the magnetic metal parts left. It ate all the alloy, he had the cost taken from his pay packet.
1990 ZG1000 C10
1982 KZ1000 LTD
Offline Feo
« Reply #7 on: December 03, 2011, 08:49:55 PM »
Were those carbs mine?  :o
I haven't unwrapped them yet, did a 450 mile lunch trip today, so I'll prolly get to work swapping them tomorrow night.
And the ones one the bike right now will be headed your way for another member.
« Reply #8 on: December 03, 2011, 09:50:33 PM »
  I dunno, what's your first name - I didn't recognise 'Feo" . If I did them in the past week, i did them in the ultrasonic - Steve
Offline 2fast
  • COG #6497, North Central Area Director
    • C-10 Heat Shield photos
« Reply #9 on: December 04, 2011, 07:06:29 AM »
Try setting a concrete block on the lid. It really helps keep the sound inside.
Got any "after" photos ? :pukeface:
I'm guessing it looks something like this........
Brian in Minnesota
Need Heat Shields for the C-10? 86-93 Front Brake upgrade brackets?  I got em! Click the little green globe under my Avatar on the left.
« Reply #10 on: December 04, 2011, 06:41:40 PM »
ohhh, poor kitty, she was such a good cat, always the first one in the tub for her bath...  :nuts:
Offline 2fast
« Reply #11 on: December 04, 2011, 07:05:38 PM »
Zat the cat named "Bones"?
Brian in Minnesota
Offline GeeBeav
« Reply #12 on: December 05, 2011, 12:09:49 AM »
. . . or Lucky?
« Reply #13 on: December 05, 2011, 07:04:27 AM »
. . . or Lucky?
Let me guess. The Cat's name "yus-ta-be" "Spot"??
« Last Edit: December 05, 2011, 10:43:30 AM by connie_rider »
« Reply #14 on: December 05, 2011, 08:03:53 AM »
for those who are feeling "concerned" about what you've seen here, I'd like to assure you that no carbs were hurt in the making of this thread.
    :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o Steve
« Reply #15 on: December 05, 2011, 10:45:26 AM »
Oooo--wheeee, that sure takes a load off of my mind!   ;D
Ah feel better already....
Ride safe., Ted
Offline WiConnie
« Reply #16 on: December 05, 2011, 10:50:43 AM »
Some of the new cleaners that were devolved to replace the old harmful solvents have a flash rust inhibitor built into them.
New to me 97
Germantown, WI
Offline timmerz
« Reply #17 on: December 18, 2011, 10:45:59 PM »
Holy mackerel...our buddy Steve's into cutomizing the kitties, now? I can see it already: the Shouldabeenkitty line-up...
