Kawasaki Concours Forum
Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C10, aka Kawasaki Concours - The Original
Accessories and Modifications - C10
(Moderator:
George R. Young
Heated grips resistor broke off from wire
« previous
next »
Print
Go Down
Author
Topic: Heated grips resistor broke off from wire (Read 1877 times)
lprising
Newbie
on:
July 27, 2011, 07:30:22 PM »
I'm afraid this is something more serious.
While trying to rewire the heated grips, one end of the ceramics resistor broke off from the wire right at it's body. Can I buy a new resistor anywhere or I am completely screwed?
(I was thinking of soldering on the wire again, but there is nothing left at the resistor's body, just a shiny dot where the connection used to be...).
Thanks for any tips in advance
Las
Logged
SteveJ.
Arena
Full Member
Country:
Re: Heated grips resistor broke off from wire
Reply #1 on:
July 27, 2011, 07:50:08 PM »
Instead of using a resistor, use a universal turn signal flasher. I have a mechanical(thermal) one on my KLR, works well, quite frugal. I would think those solid state ones will last longer, but the cheap mechanical one just keeps on a trucking.
Logged
America's Seaplane City
lprising
Newbie
Reply #2 on:
July 27, 2011, 07:56:28 PM »
Thanks SteveJ - that's quite an original idea! I will try it.
Thanks again
Las
Logged
Electroken
Jr. Member
Country:
Reply #3 on:
July 28, 2011, 03:56:51 AM »
Quote from: SteveJ. on July 27, 2011, 07:50:08 PM
Brilliant! That's a cheap, efficient, and readily available method for getting 50% power out of heated grips. I hadn't heard of that one before.
Logged
SteveJ.
Arena
Full Member
Country:
Reply #4 on:
July 28, 2011, 07:15:22 PM »
You're both quite welcome.
See, even a blind squirrel finds a nut once in a while.
I think I picked that up on a KLR forum. People over there take being cheap as a badge of honor.
Logged
Print
Go Up
« previous
next »
(Moderator:
George R. Young
