Author Topic: TPMS installation.  (Read 1622 times)
Offline mrlee
TPMS installation.
« on: June 05, 2015, 10:46:45 AM »
I need some help with TPMS sensor installation.  I removed the sensor from the back wheel of my Concours and took it to the local battery place for battery replacement ($9.99-less than a new battery shipped from Digi-Key).  When I went to reinstall the sensor, after tightening the stem to the sensor, the top of the sensor is not flush with the rim.  I didn't really notice if this was the case when I removed the sensor.  Is this correct?  Should the body of the sensor be about a quarter inch from the rim?  If not, could you let me know what I did wrong?  Thanks in advance.
2008 ABS Concours
Offline JoeRau
Re: TPMS installation.
« Reply #1 on: June 05, 2015, 11:25:14 AM »
Sorry, I can't help.  When the batteries went in mine, I had them replaced under warranty.  Never saw them.  I'm sure someone here will know the answer.
2012 C14.  Black
COG member 10990
Offline Rotello
« Reply #2 on: June 05, 2015, 07:55:16 PM »
When I changed mine, it was at least 1/8 in. from the rim.
