« Reply #3 on: February 21, 2015, 07:33:56 AM »
without [handlebar] risers, the tubes can only be raised just a small bit. (they will hit the base of the bars)
You are correct. I don't remember the exact clearance, but it was pretty small (maybe 1/2"?) without having handlebar risers. One probably wouldn't want to drop the front by more than about an inch (which is 1 1/8" at the tube, to match the 1" lowering on the rear) because the front suspension could bottom out on large bumps and smash the fender (so far that has never happened to me, but I also only weigh 145lbs and only ride solo).
Logged
