Hello, First, I am a dual sport and dirt rider. I rode street back in the 70's and 80's. Quit riding per now ex-wifes request, and am now ready to crack open a throttle down the highway.
SO, a customer owes and has offered a 87 Concurs as part trade.
It only has 24,250 miles. Most of the dings are from various storage events.
SO, I charged the battery, drained the tank, and flushed the clutch reservoir.
The oil in the clutch tank was a very nasty yellow.
After a little hesitation, the bike fired up, and I did a 100 mile freeway run.
The engine is awesome.
The big problem is the clutch slips intermittently.
When I first start out it will hold past 5000rpm on moderate acceleration.
Once it's been running for 20 minutes it will slip on almost any throttle past 4500 -5000. And will also give out on wide open low end throttle.
I didn't change the oil. The bike was purchased through a dealer 3 years ago, and only had a couple thousand miles since.
I would just consider this a worn clutch issue, but the current owner swears there was no issue when they parked it.
I do not have the maintenance records. The only "new" work was a dealer oil change 2 years ago.I would just consider this a clutch replacement issue but thought the factory clutch would be good for more than 24k.
If it is a simple worn out issue, I don't have the manual yet, but replacement looks like the right side case.
Aside from pre-soaking the plates before install are there any other clutch replacement tips for this bike?
Thanks in advance for any advice.
