I finally ran the Eastern Beaver harness on the bike today. Have panel in tool tray now, so a few questions are:
1- how many things can or should you wire to battery directly? I already have the bullet lights and the HID lights hooked to battery and this would make the 3rd item running directly from there.
2- I would like to install a 15amp unswitched powerlet to the dash, is this to much? or unnecessary ? I thought good as a charging outlet if needed but a small compressor as well maybe?
3- How much can the 2 wires at tail of bike under seat handle charging wise? I'm gonna be installing one of the powerlet setups through the tail trunk to charge phone , etc. inside trunk and thought of using these wires for that or should I just run off of fuse panel I installed?
4- How do you decide which fuse size to use? Do you use what the item your running is rated for ? Less than rating?More than?
I know lots of questions but want this done right especially since I'm doing it and I'n no electrical guru. Thanks
