So, this was a test of the Rigid Duallys and new Cyclops Long Range LED lights. I used the same mounting point for each run, set 90 degrees to the ground and parallel to each other. Trying to create an equal test shortchanged the Cyclops lights as they are a 10 degree beam and need to be aimed differantly. And FWIW the video didn't do either set of lights justice. For long range lights the Cyclops rules the road, I could see running gravel roads at night at the same speeds I would run in daytime. The Rigids would be better in the woods as they are more flood than spot. I will eventually have a set of the 20 degree lights from Cyclops for comparsion, but for what I will be doing I will be running the 10 degree in combination with the 610 Penetrator light bar. Fill up close and distance for the road. If I do some night time trail work I will have on the helmet mounted HID (Cyclops Solstice). Still undecided if I will take the Solstice to Colorado as I don't "Plan" on extended night time riding, but, well, I do have a timeline so I may be forced to ride at night.
Tell me what you think.
www.youtube.com/watch?v=clpzyL0F870www.youtube.com/watch?v=vQUKe2WAZ9Y
