Author Topic: PCV Question.. AND YES I SEARCHED!! :)  (Read 2086 times)
Offline Xelvic
« on: March 13, 2013, 05:53:17 PM »
So I can't really find a solid answer on where to ground the PCV at. I've read that the bolt for the reservoir was not good. Can I just ground it to the battery? It should be here on Friday and want to install it. My bike is a 2012 C14 that is stock except I pulled the flies. I can't wait to feel the results.
2012 Kawasaki Concours 14
Re: PCV Question.. AND YES I SEARCHED!! :)
« Reply #1 on: March 13, 2013, 06:41:46 PM »
I ground mine in 2 places. One bolt to the frame, and ran another wire from there to the battery. Been 3 years without a hiccup, or corrosion forming at the connections.
« Reply #2 on: March 13, 2013, 07:08:48 PM »
I am one of the lucky few I reckon that has had no issues using the reservoir bolt since 2008.  Some 52,000 miles, so it must not be that bad ;)
Offline jwolffie
« Reply #3 on: March 13, 2013, 10:35:45 PM »
The current will follow the shortest path back to the battery anyway, so yes you can ground to the battery.
Black 2011
Full Delkevic no cat, Ivan's Flash, Projector headlights, Dunlop Q3+
Valentine 1 with JBV1 on phone
Offline robbie
  • Tampabay, FL
« Reply #4 on: March 20, 2013, 05:54:48 AM »
+1... no problems been on since '08.
2009 Kawasaki Concours 14, 2003 Goldwing, 2002 Goldwing, 2015 F-150, 2018 JK Wrangler, 2002 TJ Wrangler
« Reply #5 on: March 20, 2013, 06:20:08 AM »
I used the accessory leads in the boot on the left side of the dash.
