Looks great Steve!
One thought for a first timer doing this,,,
"be sure the screwdriver is straight in-line with the cylinder when pressing the starter button".
If the screwdriver is at an angle,,,, could cause a problem.
To be sure mine is straight, I beat the porcelin out of an old sparkplug and removed the ground electrode.
Then I screw the remaining metal sparkplug body into the hole and use the inside of the sparkplug as a guide.
