Author Topic: What did you do to your Concours today?  (Read 975981 times)
Offline zarticus
« Reply #2000 on: March 16, 2016, 06:31:33 PM »
Painted the rims, handle bars, rear grad handles swing arm, drive housing and any silver metals black. I think it looks a whole lot better.
What did you use for paint ?
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline Deziner
  • Phoenix
« Reply #2001 on: March 16, 2016, 08:14:32 PM »
Got a quote of $250 to reseal the front forks.
Scored an entire front end including triple trees for $255.
Like a boss!
Offline kwakrider
  • Country: za
  • Black- 2009
« Reply #2002 on: March 17, 2016, 05:37:39 AM »
Like a boss!
Sweet!!  :thumbs: :thumbs:
Offline kzz1king
« Reply #2003 on: March 20, 2016, 05:15:06 PM »
Does the piece supplied  with the changer fit in the axle of the 14? I know it is too large for the C10. Just got mine today and cant wait to use it. Even if I end up using tire irons I will be able to stand rather than crawl around on the ground.
Wayne
Tom, some think its a curse  :o
I did the rear tire first, and I used the stupid contraption on this tire machine that holds the upper part of the center (axle) rod. It was more of a hinderance than a help. When I did the front tire, I did it just as how the machine looks here. Easy peasy! I have now saved my first $60 dollars in tire expense. However, I have about $250 into getting my own equipment.
This is the Pit Posse balancer that I bought from amazon for $50. Very nice sturdy balancer.
2010 CONCOURS
1974 Z-1
sailor_chic
« Reply #2004 on: March 20, 2016, 07:26:53 PM »
No, the center rod supplied with the changer is too big to fit the bearings. I went to Lowe's and bought a 1/2" solid steel rod and that works great, even without the upper attachment on the changer. I found the upper part was more of a hindrance than an asset.
Offline kzz1king
« Reply #2005 on: March 20, 2016, 08:13:16 PM »
Thanks!
2010 CONCOURS
1974 Z-1
sailor_chic
« Reply #2006 on: March 21, 2016, 03:30:17 PM »
I ordered new oem brake pads for front and rear today. I can't believe the cost. It's the bend over and grab your ankles kind of expensive! (easy boys)
Offline Arkkangel
« Reply #2007 on: March 21, 2016, 04:41:21 PM »
I used Krylon Cover Max rattle can black satin and shot it with clear, just did a lot of prep on the parts...the silver parts left are going to be powder coated because they are in places the boots will rub on them..
« Reply #2008 on: March 21, 2016, 05:40:28 PM »
You think that's bad, wait till you have to order new rotors. No choice but to go EBC because who can afford OEM rotors?
« Reply #2009 on: March 22, 2016, 04:57:07 AM »
That's why I went with EBC's. No bending over required...
sailor_chic
« Reply #2010 on: March 22, 2016, 05:21:52 AM »
But you have to deal with noisy brakes instead, or at least I've read many complaints about ebc.
« Reply #2011 on: March 22, 2016, 05:33:46 AM »
This stuff has always solved my noisy brake problems.
sailor_chic
« Reply #2012 on: March 22, 2016, 05:46:48 AM »
I have the aerosol type works well too
« Reply #2013 on: March 22, 2016, 06:09:41 AM »
Last time I went to replace pads, I already had a set of OEM pads but found the rotors were run out. So I put a set of EBC rotors with OEM pads. I used the brake quiet and the only problem I had was when backing up, the front brakes would squeal. But after a few days it stopped and they work great now. I guess they just needed some breaking in.
Offline Deziner
  • Phoenix
« Reply #2014 on: March 22, 2016, 07:34:01 AM »
Generally speaking, they do stop squealing after you break them in. ::)
« Reply #2015 on: March 22, 2016, 09:27:58 AM »
Once broken in I didn't have any squeaks or squeals but the EBC's do make a hissing sound when applied that the stockers didn't seem to have.
« Reply #2016 on: March 22, 2016, 10:02:31 AM »
The hissing usually comes after the squeaks and squeals.
« Reply #2017 on: March 22, 2016, 10:51:52 AM »
Loud brakes save lives. 8)
Offline kzz1king
« Reply #2018 on: March 22, 2016, 11:11:47 AM »
Are we still talking brakes here? 8)
2010 CONCOURS
1974 Z-1
« Reply #2019 on: March 22, 2016, 01:29:47 PM »
We're multitasking.    :)
