Author Topic: Brake pad wear in millimeters  (Read 5433 times)
Offline 2talltim
  • 2008 C14
« on: May 21, 2014, 09:12:37 PM »
Ok instead of bumping up another brake pad thread, that i did search for a read and couldnt find my answer.  I have a quick question, at what point would you change pads going by mm thickness of the pad? I read on the COG forum that stock pads are 3.8mm the thinnest pad i have is 2.2mm. how thin would you go in millimeters before you changed? FYI i have Gallfer gold HH pads with about 13k(ish) miles on them. Those measurements are the pad material only not including the backing.
Offline udoggie
Re: Brake pad wear in millimeters
« Reply #1 on: May 21, 2014, 11:27:08 PM »
The wear bars are typically at 1mm.
I wish I could see mine.  I did a safety check last weekend, and found they were all gone.  I sure hope they get here by the weekend...
Jeff
Aloha, OR.
« Reply #2 on: May 22, 2014, 04:22:27 AM »
According to my 08 manual, the Kwak pads are 4 (.16 inches) and 5 mm (.20 inches) thick for the front and the back.  Wear limits on both are 1mm or .04 inches.
Offline 2talltim
  • 2008 C14
« Reply #3 on: May 22, 2014, 08:13:30 AM »
Okay thanks,I must of gotten some bad info on COG or maybe that was for a C10. I'll let them go for a little longer, might go ahead and rotate them since the outside pads are slightly thicker.
Offline 2talltim
  • 2008 C14
« Reply #4 on: May 22, 2014, 08:17:59 AM »
Jeff
The galfer fronts don't have wear bars that I'm away aware of.
Offline Daytona_Mike
« Reply #5 on: May 22, 2014, 09:14:27 AM »
Is that a good idea to rotate them?
I would think that there is an issue with dirty pistons if the pads are not wearing evenly.
Offline 2talltim
  • 2008 C14
« Reply #6 on: May 22, 2014, 09:39:36 AM »
Every bike I've ever owned has worn one side slightly more than the other. I'm not talking a huge difference just maybea half a millimeter or less.. Most cars are that way too.
« Reply #7 on: May 22, 2014, 09:47:41 AM »
If yer already in there why not just replace them? Pads are pretty cheap...  :-\
Offline 2talltim
  • 2008 C14
« Reply #8 on: May 22, 2014, 10:41:30 AM »
$120 ain't cheap in my book, I'm just a po country boy.
« Reply #9 on: May 22, 2014, 03:48:21 PM »
You should check out the EBC double-H pads, I love em, and you can get em for like $80.  :thumbs:
Offline 2talltim
  • 2008 C14
« Reply #10 on: May 22, 2014, 07:21:07 PM »
think im good for a little bit but i still thought about ordering a set to have on the shelf, found those on sale on amazon $74 with free shipping  http://www.amazon.com/gp/product/B005JJ2UAK/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Offline PH14
« Reply #11 on: May 23, 2014, 09:40:37 AM »
Murph has them. I just bought a full set. Mine are still good but I figured I will have to replace them at some point. I had to take the bike for inspection so I pulled the fronts to see how they were, they still look just a hair under half good. I cleaned the pins, put a bit of brake grease on the contact points and put it back together. The new pads aren't here yet. I did cure the loud squeak I had under light braking though.
http://www.murphskits.com/catalog/product_info.php?products_id=357
« Reply #12 on: May 23, 2014, 12:31:02 PM »
informative thread
