that's a bit high;
from the manual/
•Measure the fuel pressure with the engine stopped.
Fuel Pressure
right after Ignition Switch ON, with pump running:
Standard: 304 kPa (3.1 kgf/cm², 44 psi)
after 3 seconds from Ignition Switch ON, with pump
stopped:
Standard: 280 kPa (2.9 kgf/cm², 41 psi) , residual fuel
pressure
The system should hold the residual
pressure about 30 seconds.
•Start the engine, and let it idle. •Measure the fuel pressure with the engine idling.
Fuel Pressure (idling)
NOTE
○The gauge hand will fluctuate. Read the pressure at the
average of the maximum and minimum indications.
from the manual...
also flow:
67ml (2.26oz) during the 3 second test.
good luck.
