Author Topic: What did you do to your Concours today?  (Read 1011669 times)
Offline zarticus
« Reply #2540 on: October 14, 2016, 04:35:12 PM »
Theres plenty of wire for different mounting options. I cut some off to get rid of the extra. I drilled a small hole next to the hinge for the lid, and ran the wire up through the bag, drilling another small hole above the rear hook, then ran the wire to a connector under the seat. Used a couple pieces of duct tape to hold the wire down, following the creases inside the bag to keep the wire out of the way. I'll get a picture for you later.
Actually I was referring to the length of the light itself if it is the exact length or did you bend the light towards the front of the bike ?.
   Thanks
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline J.R.
« Reply #2541 on: October 15, 2016, 05:57:23 PM »
   Thanks
Gotcha! The light is about .5" longer than that small ledge on the underside of the bag. No bending, its mounted flat on that ledge.
Jim
2016 C14 "Kristi"
Offline Eupher
  • U.S. Army, Retired
« Reply #2542 on: October 16, 2016, 10:09:02 AM »
Installed Brian's KiPass bypass harness. Hope I never need to use it.
It was also my first foray into taking that little piece of the fairing off. Fred Harmon's videos definitely help in that department. Freakin' plastic is expensive.  :P
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Offline zarticus
« Reply #2543 on: October 16, 2016, 09:07:48 PM »
Awsome, Thanks !!
Offline O.C.
« Reply #2544 on: October 17, 2016, 07:03:32 AM »
Attached a GlareStomper to my GPS device...the last GlareStomper lasted 9 years so was due a replacement  :)
http://www.glarestomper.com/322/#axzz4NLaWxLIX
CARPE DIEM
KAWASAKI VERSYS 650
Offline Charlie747
« Reply #2545 on: October 17, 2016, 05:50:19 PM »
Fitted crashbars to my other ride on Saturday after a cuppa with friends at the Ace Cafe London
« Reply #2546 on: October 17, 2016, 05:56:32 PM »
Took a ride down under when you left the Ace?
« Reply #2547 on: October 17, 2016, 08:10:03 PM »
Charlie, is that Debs?
Offline O.C.
« Reply #2548 on: October 18, 2016, 04:29:42 AM »
On behalf on Charlie...that's our Debs  :)
CARPE DIEM
KAWASAKI VERSYS 650
Offline sanmo
« Reply #2549 on: October 18, 2016, 09:32:30 AM »
This was the flasher i bought: "Purishion 2x Flash Strobe Controller Flasher Module for LED Brake Light Tail Stop Light 12-30V " https://www.amazon.com/dp/B01HPSZZXQ/ref=cm_sw_r_cp_api_dxpaybZMK4181
Good information J.R. I assume the second flasher is not really needed? Also, you mentioned some plug under your seat for connecting the new lights. Any reason why the  new lights cannot simply tap into the existing brake/tail light and turn signal wires?
2008 Silverdammit C14
« Reply #2550 on: October 18, 2016, 06:43:36 PM »
 :thumbs:
Offline J.R.
« Reply #2551 on: October 19, 2016, 09:15:03 PM »
No, the second flasher isn't needed. I may wire it up to my trucks third brake light.
All the wires do tap into the existing brake and turn signal wires. The reason for the plug is to be able to remove the bags. That way I can just just unplug them if I need to take them off, and not mess with any of the connections.
Jim
2016 C14 "Kristi"
Offline qyetman
« Reply #2552 on: October 25, 2016, 03:58:52 PM »
Added super inexpensive brake light today. Walmart strip LED's, $8.
« Reply #2553 on: October 25, 2016, 08:19:00 PM »
Hellavalot cheaper than an Admore, although it does look a bit Xmas treeish  :)
sailor_chic
« Reply #2554 on: November 10, 2016, 07:22:39 AM »
My neglected bike has been sitting for 5 weeks now. The rear tire is half flat, but only on the bottom.
Offline zarticus
« Reply #2555 on: November 10, 2016, 07:38:24 AM »
Just ride on the top part  :rotflmao:
« Reply #2556 on: November 10, 2016, 08:50:02 AM »
I installed  a Delkevic Slip On and ran wires for grip heaters that should arrive in a few days.
Offline kzz1king
« Reply #2557 on: November 10, 2016, 08:52:09 AM »
I was in the same boat. 5000 on the Angel GT, 2 plugs and it wasnt doing it for me anymore. Normally end of riding season here but November has been warmest on record. Put a  023 batttalaxe on last weekend. Good to be on two wheels again. Withdrawal is a real thing in the north country.
Wayne
2010 CONCOURS
1974 Z-1
Offline kzz1king
« Reply #2558 on: November 10, 2016, 08:52:56 AM »
Just wire them in and go?
Wayne
2010 CONCOURS
1974 Z-1
Offline O.C.
« Reply #2559 on: November 10, 2016, 12:23:30 PM »
No riding out here at the moment, its very cold averaging about 2c during the day and if you factor in the wind chill its definitely a minus c figure ...brrrrrrrrr
On top of which we had about 3 inches of snow overnight Tuesday and Wednesday morning so riding the big bike is a no no
Back in the day I would've got an off road bike out of my Rev Shed and gone for a blast, alas I'm past all that kinda stuff these days, and only have the GTR now  ;)
CARPE DIEM
KAWASAKI VERSYS 650
