FWIW, I had the front and rear wheel bearings replaced this week during a tire installation on my '86 w/35K. I bought the bike from the original owner who kept excellent maintenance records, and it showed the bearings had never been replaced. The technician showed me the original bearings and they looked absolutely fine.
Given the cost of the parts and the labor to install, I would think twice about replacing wheel bearings again.
Just my two cents...
Well after adjusting for inflation your .02 does not go very far at all..... FYI the 86 through 94 (?) used a larger front wheel bearing than later years and they did last much much longer than the later models; some would fail within 20,XXX miles. The rear wheel bearing were much larger and do tend to last a very long time often a lifetime. But I question your cost as all four of these bearings should not have set you back much more than a 20.00 bill. What you were charged for labor depends on a lot of variables such as bringing in wheels only or an entire bike etc. I myself can bang out an old set and install new front and rear wheels only in under an hour.
Tony, slight correction. That would be 86-93. 94 was the first year for the new wheels, brakes, etc.I guess "nut busters" aren't perfect either.
Well, with the rears running in gear oil just like semi-trailers do they may last forever. The fronts can go at anytime and when they do it ain't pleasant. I was slowing down from 70mph into Sparta, WI when the whole front end started to wobble. I ended up riding in 1st gear back to the motel and the front end was going up and down like a clown-mobile. I'm lucky I didn't end up in a ditch because those puppies were completely shelled. The odometer showed 26K when that happened.
Well, with the rears running in gear oil just like semi-trailers do they may last forever....
I'm sorry Craig but this is completely inaccurate information... The rear wheel bearings are sealed bearings that are mounted in the wheel and have absolutely nothing in common with the rear differential whatsoever other than the fact that the wheel hub is splined into the differential.
Duh! Right you guys are. I knew better than that! Too many beers!
