Author Topic: dash led bulbs  (Read 22662 times)
Offline yoman
Re: dash led bulbs
« Reply #20 on: January 29, 2013, 03:47:30 PM »
how did you remove the dash?
2002 Semi-naked Connie
Offline yoman
Re: dash led bulbs
« Reply #21 on: January 29, 2013, 03:54:01 PM »
I ride a lot in the dark, so I don't like bright dash lights glaring at me. I used blue tinted singles for dash illumination, and 4 gang for indicator lights. I left the stockers in the clock and high beam. Except for the bottom odometers, the blue singles work nicely.
They look "cooler" in person.
I'm diggin' the blue.
Offline m hanlen
Re: dash led bulbs
« Reply #22 on: January 29, 2013, 04:35:01 PM »
yoman,
1 Remove the windshield
2 Remove the 1 screw under the windshield forward of the dash on top
3 remove the glove box covers
4 remove the 3 screws in the bottom of each box
5 Now I cheat here and carefully roll the cluster cover back and out of the way of the pockets, They will lift up enough to get it out. Disconnect the two leads to the clock
6 disconnect the speedo cable from the wheel (it will give you more room to disconnect it from the speedo)
7 with a 10mm socket remove the 2 screws under the cluster (don't drop them, you'll never see them again)
8 raise the cluster, disconnect the wiring harness and speedo
9 the bulbs are in the 3/8" plugs on the back, gently pry the up and pull the bulb out. pay attention to the wire colors and bulb polarity. they won't work if you put them in backwards, led's are polarized. Just takes an hour. I like the blues, reds and yellows but I'm old school.
Offline yoman
Re: dash led bulbs
« Reply #23 on: January 29, 2013, 04:37:39 PM »
yoman,
Exactly what I was looking for, thanks.
Offline Uded2me
This forum is dead dead dead
« Reply #24 on: February 01, 2013, 12:49:33 PM »
d e a d
« Last Edit: February 21, 2016, 09:24:17 PM by knight_mare »
Offline yoman
Re: dash led bulbs
« Reply #25 on: February 01, 2013, 03:18:08 PM »
if the bulbs are hooked up with the polarity reversed, will it harm the LEDs or will they just not work?
Offline m hanlen
Re: dash led bulbs
« Reply #26 on: February 01, 2013, 05:39:12 PM »
No, not at all, just won't work until you turn it around.
Offline timmerz
Re: dash led bulbs
« Reply #27 on: March 22, 2013, 08:27:43 PM »
I'm about to take the plunge and try and follow you guys on the path to better lighting....can't see how fast I'm going at night any more, and like I've been reading, the high beam blue is darned annoying...
Can anybody advise if any of these parts schemes will work on old-school Connies? Specifically, a '92 like mine? Or, failing that, has anybody done this upgrade on their older Connie and can share the details?
Offline m hanlen
Re: dash led bulbs
« Reply #28 on: March 22, 2013, 10:41:49 PM »
It'll work fine, there's not that much difference in the tow models. i would leave hi beam alone. It's too bright. Pick a color and have fun. I'd still like a little brighter clock light.
Offline timmerz
Re: dash led bulbs
« Reply #29 on: March 23, 2013, 11:28:48 AM »
Ok, I'm in the superbrightled website, looking at bike dash lights, there is an option for narrow or wide-angle on the bulbs....I'm kind of assuming here, but I'd probably want narrow (32 deg) for the lensed bulbs (indicators) and wide (90 deg) for the background (dash glow) bulbs, right?
Offline kbecker3
Re: dash led bulbs
« Reply #30 on: March 24, 2013, 02:55:54 PM »
I got mine from Super bright leds.com. I got the single led (WLED-g-120). Basicly 194 bulbs, the wide angle (120 degrees) green. along with a red and blue for the indicators and the green 74 bulb for the clock.
these are the 194 bulbs:
http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-1-led-wedge-base/197/
2005 concours
Offline m hanlen
Re: dash led bulbs
« Reply #31 on: March 24, 2013, 03:15:26 PM »
But isn't that just 1 led and isn't it dimmer than a 4 led, 5 Lumen
http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-4-led-wedge-base/198/
My 4 led bulbs were just right. 15 Lumen
Offline kbecker3
Re: dash led bulbs
« Reply #32 on: March 24, 2013, 05:13:44 PM »
yep, single led is what i used. I thought the 4 led ones looked too bright. The bottom of my gauges are a little dark, but i think its just right for me as i dont like my gauges too bright. You can see mine on the first page of this thread.
2005 concours
Offline Uded2me
« Reply #33 on: March 26, 2013, 02:53:53 PM »
d e a d
« Last Edit: February 21, 2016, 09:25:26 PM by knight_mare »
Offline timmerz
Re: dash led bulbs
« Reply #34 on: March 26, 2013, 08:04:44 PM »
Very cool ideas, I will definitely use them if the single-led still proves to be too distracting when the high-beam is on....
Offline pranje
Re: dash led bulbs
« Reply #35 on: April 19, 2013, 09:20:22 PM »
I just switched my dash over to the LED's. What I did rather than pop out the lense for the high beam, was color the end of the bulb with a black sharpie. I played around with mine on the bench. I ran temp power to the gages and tested each light before I mounted back up. The sharpie on the bulb is close to perfect. I don't think it will burn off too quickly seeing that I don't get to run for long periods of time with the highs on. And if it does I only have to pull that bulb out, not the whloe meter pod. FYI for anyone considering using red LEDs; single red LEDs are not bright enough, I ended up needing to order the four LEDs for the (4) main meter lights.  Also red on the clock is not good, I have tried both the single  and the SMD (?) and both are hard too see. I will be ordering a green SMD most likely.
Jason on the Great North Coast!
Offline gtr a14
Re: dash led bulbs
« Reply #36 on: September 03, 2013, 07:18:30 AM »
 :D hi, great site, have just replaced my dash bulbs with 4 led bulbs. I went for blue and am very happy, i ordered the bulbs from "hong kong" via ebay- 6 4led bulbs for 99p and free delivery. took 14 days but for less than a pound !!
Offline m hanlen
Re: dash led bulbs
« Reply #37 on: September 03, 2013, 08:19:44 AM »
That is 99p ($1.50) each, correct?
In Jan 2013,
I bought the 4 led
PRODUCT(S)
Qty    Product/Options    Price/Ea
1    WLED-x4-x: 194 LED Bulb - 4 LED Wedge Base WLED-R4-90: Red Wide    $1.59
7    WLED-x4-x: 194 LED Bulb - 4 LED Wedge Base WLED-G4-90: Green Wide    $2.59
1    WLED-x4-x: 194 LED Bulb - 4 LED Wedge Base WLED-B4-90: Blue Wide    $2.59
1    74-xHP: 74 LED Bulb - 1 SMD LED Wedge Base 74-GHP: Green    $2.49
SubTotal:    $24.80
Sales Tax:    $0.00
Shipping:    $2.99
TOTAL:    $27.79
® 2002-2013 Super Bright LEDs Inc.
4400 Earth City Expressway
St. Louis, Missouri 63045-1328
Offline gtr a14
Re: dash led bulbs
« Reply #38 on: September 03, 2013, 08:44:14 AM »
Hi, no 99p for 6 4led smd  194 bulbs. Ijust replaced the main dials, not the oil,neutral etc, so only 4 bulbs needed leaving 2 for spares.
Offline m hanlen
Re: dash led bulbs
« Reply #39 on: September 03, 2013, 10:16:48 AM »
Got a web site?
