No, because when you adjust 3 you don't affect the 3-4 adjustment. effectively adjusting 3 moves both 3 and 4 the same amount. SteveA lot of folks get tripped up on that. BTDT.
Steve, now that you are a star, I see that the studio is taking advantage of you and has you really cranking them out.
I really prefer to pull the rpm's up around 4k and trim the settiing abit, then drop to idle and see what it yields. Sometimes you can get the sync to stay pretty close across the board. what you see there was the result of that - best all around, and the differences were really very minute. there' alot of ways to skin the cat, no way is the "only" way. HTH, steve
