The C-14, aka Kawasaki Concours-14, the new one :) => Accessories and modifications - C14/GTR 1400 => Topic started by: stevewfl on January 28, 2014, 11:52:52 PM
OK so some boys told me about this mad sale on amazon, "$20 bux to your door" for bright waterproof 12V LED work lights. Perfect, been wanting a low wattage bright worklight for my C14 for quite some friggin' time.
So, I ordered the "60 flood". Although they have several on sale for the cheap. Here is the one I ordered: http://www.amazon.com/gp/product/B005WWIV3O/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1 (http://www.amazon.com/gp/product/B005WWIV3O/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1)
*1200 Lumens Latest design, 2013 model LED light as shown with advanced 27W LED output using 9 x 3W CREE type LED Chipsets.
*Genssi (TM) - 3W LEDs x 9pcs in Each Ultra Bright - See Pictures Black Finish for long lasting durablity Low weight Aluminum housing+ Steel
*Listing is for one light Lense material: PMMA transparent thermoplastic
*Round Lense and Housing as shown with FLOOD 60 Degree Type Lense output Input voltage: 10V-30V
*Mounting Bracket: Stainless Steel Size: 110mm x 55mm x 128mm 30,000 Life Operation LED light output 6000K Current Draw: 2A @12V, .9A @ 24V Waterproof rated IP 67
Now, I want it to work on my C14 cigarette 12V port (or truck when I have the KTM out or on a trip and may need under the hood lighting.
So I gather a scrap 12V plug and cut the end of, enough old speaker wire to go about 3 truck lengths, some heat shrink tubing, soldier, and the FRUGAL waterproof work light.
Here is my junk:
(http://i80.photobucket.com/albums/j180/stevewfl/KTM/SWP_4212.jpg)
And here it is after my cutting, stripping, soldering and heat shrinking is done. I also used a multimeter and "ohmed out" to make sure my 12V and grounds were correct.
(http://i80.photobucket.com/albums/j180/stevewfl/KTM/SWP_4215.jpg)
And here is working with garage dark, its plugged into the 12V outlet of the Connie14 (engine off). Its so bright I'd back it up if i was really working on a bike/car/tent with it.
(http://i80.photobucket.com/albums/j180/stevewfl/KTM/SWP_4219.jpg)
Brilliant!
Illuminating!
I have seen the light!
The light at the end of the funnel.
$20 worth of it, wanted to FYI in case you may want the deal too ;D
Lighten up. ;) Thanks Steve, looks like a good deal.
(http://i80.photobucket.com/albums/j180/stevewfl/avatars/lol.gif) (http://i80.photobucket.com/albums/j180/stevewfl/avatars/lol8.gif)
With these lights rated as IP67 waterproof, is there any reason why we couldn't use these as auxiliary/driving lights ?? And at $40 a pair that's an amazing deal.
Without searching like mad can anyone tell me if these come in a spot version?
Dan
Dan
That's what I was thinking.
http://www.carhidkits.com/27w-round-led-spot-flood-light-white-402.html (http://www.carhidkits.com/27w-round-led-spot-flood-light-white-402.html)
But 30 degrees is still rather wide. Add a dimmer to run as a conspicuity light and walla!!
At $40 !
That's very nearly free compared to what a lot of guys are running
Dan
I think it's funny how one site claims 1200 lumens and the other site claims 2000+ lumens ;D
Dan
Possibly one site is brighter than the other..?
Sweet! I just ordered two of the square framed 30-degree version for my tractor ... Stated $19.99 each, but Amazon applied a $2.00 promotional discount to each without me doing anything. :)
$35.98 total (I selected slow FREE shipping)
C'mon...anyone going to try these on their C-14 ??
Someone should light the way.
I'm trying them on my tractor ... because I'm delighted.
At around 4.5" inch each, it may be a bit much?
