Here is some things I DON'T MISS about my Beemer.....
1. Throw the bike on the centerstand.
2. Remove side cases.
3. Unbolt the exhaust can from its mount and loosen at the midpipe.
4. Rotate the exhaust can away from the rear wheel.
5. Remove the rear wheel.
6. Remove the rear brake.
7. Remove the speedometer sensor.
8. Unbolt the top of the final drive retaining link.
9. Place drain under final drive.
10. Remove final drive drain plug.
11. Rotate final drive assembly down and drain oil.
12. Rotate final drive assembly upwards, seating dust shield and engaging drive shaft splines.
13. Using a 100 mL horse syringe, meter in 180 mL of final drive oil**
14. Replace speedometer sensor and rear brake.
15. Replace rear wheel.
16. Re-mount exhaust can to hangar. Tighten clamp bolt at mid pipe.
17. Replace side cases.
18. Clean up mess you made metering final drive oil through the drain plug.
**Beemer recently changed their specifications from 240 mL to 180 mL to address seal failure issues. 180 mL may be added through the drain plug, and happens to be to the bottom of the threads, making the process easier. You STILL need some sort of injector device to get it through the drain plug hole. Previously, you metered the oil through the speedometer sensor hole, which was much smaller and you had no visual indication of the level, so you actually had to measure the quantity going in. I used the previously mentioned horse syringe and a small length of fish tank air tube. The tube is not necessary if you are adding it through the drain plug.
