Author Topic: Tire bead tore up  (Read 6139 times)
Offline Awaz
Tire bead tore up
« on: June 29, 2013, 04:53:11 PM »
Did not think I was applying that much force....
2016 Ducati Scrambler
2008 C14
Offline sherob
Re: Tire bead tore up
« Reply #1 on: June 29, 2013, 06:48:56 PM »
There are a few tires that are just plain hard to put on... no matter how long I leave them in the sun to warm up, or how much goopy stuff I use.  I've had I few that I thought would turn out like that... that sucks!
Rob
« Reply #2 on: June 29, 2013, 06:55:25 PM »
This is why I pay someone else to do it...
Bullwinkle's hat gag
« Last Edit: June 29, 2013, 08:46:44 PM by VirginiaJim »
« Reply #3 on: June 29, 2013, 07:49:18 PM »
   that
« Reply #4 on: June 30, 2013, 06:10:10 AM »
I call BS. There's steel cords that would have to break. The only way a bead is gonna separate is if you cut it.
Offline Awaz
« Reply #5 on: June 30, 2013, 01:14:50 PM »
Not sure what you are referring to as BS. But why would I want to cut the bead on a tire that I just paid like $200 for? My motorcycle is now sitting on a lift with stuff laying all around for another week at least until I get a new tire. It honestly just ripped when I was trying to put that last bit of bead over the rim. I thought I broke the rim or something when I heard the pop. I called up Jake Wilson to see what they can do about this. They are suppose to get back to me on Monday - lets see if they give me a replacement tire. I honestly think something not right with that tire.
2008 C14
Offline rwulf
« Reply #6 on: July 01, 2013, 07:44:01 AM »
I think you are right, something is not right.
I've pulled cars out of a ditch with tires and not broken
the bead.
« Reply #7 on: July 01, 2013, 08:51:27 AM »
Shinko?
Offline Awaz
« Reply #8 on: July 01, 2013, 09:07:20 AM »
Shinko?
yeah...that's what I get for being a cheap b'tard.
2008 C14
« Reply #9 on: July 01, 2013, 10:03:23 AM »
Ha  :D
Offline timsatx
« Reply #10 on: July 01, 2013, 10:34:56 AM »
I had a Shinko that they stopped making and had a tire recall that got mine replace because the treads were separating. I never went back to Shinko. I now have an Azarro that replaced it.
Offline Awaz
« Reply #11 on: July 01, 2013, 11:35:18 AM »
Talked to Jake Wilson. According to them since it was a tear during mounting, warranty does not really cover it, but they were going to take care of it for me this time. I went ahead and had it replaced with a Dunlop Elite 3. Do not think it is a great tire either (not like Avon or Metzeler), but will have to do. I do not ride that thing much anyway - just needed something for the occasional putting around town. Although, I am running shinkos on my Kawi and so far they are holding up good. But next tire change, I am going with a better know brand.
2008 C14
« Reply #12 on: July 01, 2013, 11:51:59 AM »
The Elite 3....wagon wheels at their best.
« Reply #13 on: July 01, 2013, 12:42:28 PM »
Go with the Angels or the PR2's or the PR3's, that is the wise choice. Pay the price or buy it twice, heck maybe even 3 times.
Offline Outback_Jon
« Reply #14 on: July 01, 2013, 12:44:57 PM »
Just a note, Shinko bought out and took over Yokohama for motorcycle tires.
« Reply #15 on: July 01, 2013, 08:21:46 PM »
You ever change a tire bfore?
Just had to ask....cause you certainly didnnt have the opposite side sittin in the groove, and wayyyyyyyy manhandled the bead with a 24"bar.., or more... pop. Man 8-12" irons will work, more than that and c'ya bead....
Offline Awaz
« Reply #16 on: July 02, 2013, 06:29:42 AM »
I won't claim to be an aged veteran, but I have done 4 tire changes so far - two on my KZ250 and two on my C14. Not sure what you mean by 'did not have opposite side sitting in grove'. I did have the other side underneath the rim (where it should go) and had it pressed down with my knee while I was working on the other side. And I was not trying to work a big chunk at a time either - just a small bite at a time to get the bead over. When it snapped, I did pull a bit of the bead of the side I was working on to make sure I did not break or bend the rim - the sound scared me. About the bars, I will have to check - I am afraid they may be 24" spoons - smallest I can find in my local hardware store.
2008 C14
Offline Outback_Jon
« Reply #17 on: July 02, 2013, 08:06:59 AM »
The side of the tire opposite where you are levering should be pushed down into the center of the rim, not just under the rim where the bead sits once the tire is mounted and the bead seated.  If you look at the rim's cross-section, you'll notice it kind of looks like this:  └╖_╓┘  You need to make sure that the bead on the opposite side is down in that center section when you're levering.
« Reply #18 on: July 03, 2013, 05:26:32 PM »
Sorry to doubt you. I've had to get very mean to beads before, and never had one snap. I've also seen people try and saw/cut through them, and it ain't easy. ;)
I've never allowed another person to work on my bike. Never will. I sweat and bust arse to mount my tires. I've torn the rubber away from the bead, but never had one not seal or work. Once again, sorry to call BS. I just can't imagine it.
Offline Awaz
« Reply #19 on: July 03, 2013, 05:44:25 PM »
Finally got my replacement tire - Dunlop elite 3. It went in with lot less effort. I did make sure this time that the bead on the opposite side is pushed down far enough.
2008 C14
