Author Topic: Gas gauge issue?  (Read 11497 times)
Offline Mettler1
Re: Gas gauge issue?
« Reply #20 on: May 02, 2013, 08:12:43 AM »
I'm glad I found this - my fuel gauge is driving me nuts. Its showing 1/4 after only 120 miles. Last time it showed empty I put 4 gallon in.  Resistance is useful...
   cugsy, easy fix.  220 ohm resistor.
http://c10mods.blogspot.com/2011/07/c10-fuel-gauge-modification.html
Offline kzz1king
« Reply #21 on: May 02, 2013, 11:29:29 AM »
Someone here turned me unto a resister, THANKS. It makes a world of difference.
2010 CONCOURS
1974 Z-1
Offline Mr Orange
« Reply #22 on: June 18, 2013, 06:10:37 AM »
Looks like you've got Totally Wired Cycles fuel gauge adjuster installed.  They're no longer available, unfortunately.  It should have a plastic sleeve covering it to protect it.
I have one on my bike.  I've got it adjusted so I hit my reserve just as the gauge goes into the red zone.
I also have the Totally Wired version. It's a shame they went out of business they had some neat stuff. I also have their aux fuse panel which was a really nice piece of kit.
Offline cugsy
« Reply #23 on: June 18, 2013, 03:14:48 PM »
I did the ohm fix and its miles better - literally...
Bloody hell - its a heavy bike!
Offline timsatx
« Reply #24 on: July 01, 2013, 07:38:54 AM »
Does anybody have a pic of the Totally Wired version?
Offline cugsy
« Reply #25 on: July 01, 2013, 03:39:22 PM »
I might have fixed the gauge but I'm only getting 38mpg. Yik!
Offline Stasch
« Reply #26 on: July 01, 2013, 04:49:42 PM »
You have to wire tie the adjustable resistor to your right wrist to help with the mpg's.
Offline cugsy
« Reply #27 on: July 02, 2013, 04:00:17 AM »
What's really annoying is riding at a sedate 65mph ..ish and then being overtaken or tailgated by a nun in a Fiat. As soon as I speed up to a happy speed I know das polizie are waiting. Not fair  :'(
Offline Easy13
« Reply #28 on: July 04, 2013, 04:51:18 PM »
Nuns have the edge: nobody's going to write one a ticket!
It's good to have friends in high places.   8)
Cognito Ergo Wrenchum
Offline Gitbox
« Reply #29 on: July 12, 2013, 12:51:27 PM »
If you're going to take your cluster out, you can mount the resistor right on the terminals on the back of the speedo.
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
Offline Nosmo
« Reply #30 on: July 12, 2013, 11:22:54 PM »
Don't worry. The FIAT will break down looong before your Connie runs out of gas. ;)
« Reply #31 on: July 13, 2013, 12:24:37 PM »
Cugsy; As long as the policeman isn't right behind you, ya can use a system to enjoy.
Cruise in the straight area's. Play in the curves..
