Author Topic: Differences between English and English (UK vs. US)  (Read 28394 times)
Offline mikeyw64
  • Country: wales
Re: Differences between English and English (UK vs. US)
« Reply #20 on: February 28, 2018, 04:10:03 PM »
Possible alternative for both sides of the pond: "I'm going to dump, bathe and then nap."
or if you're getting ready to go out
"**** , shave & shower"
Offline mikeyw64
  • Country: wales
« Reply #21 on: February 28, 2018, 04:10:52 PM »
and of course your latest President is hilarious as "trump" over here means to fart  ;D
« Reply #22 on: February 28, 2018, 04:30:32 PM »
I believe the best system is the one the Chinese (and perhaps others) use, which is YYYY/MM/DD/Hour/Minute/Second/second decimals. This system cannot be confused and can be lengthened and shortened with no modification needed. One can specify the year or the microsecond of an event with one unchanged system.
Bingo.  And it can be sorted correctly and easily.  It is called ISO 8601, normally just called "ISO dates"
https://en.wikipedia.org/wiki/ISO_8601
YYYY/MM/DD/etc is the only logical way to write and store dates (and dates with times).  So PLEASE let me know when you have changed everyone to use it.  I find it amusing that only China and Japan use it [exclusively].  Meanwhile, I have to keep using the stupid MM/DD/YYYY so people know what the hell I am saying.  Although I have dated things the right way (ISO) and it does seem that many people understand it, as long as the day is > 12.  2018-01-02 is ambiguous (especially to DD-MM-YYYY countries), but 2018-02-27 is not.
BTW- I think DD/MM/YYYY is just as stupid, maybe even more so than MM/DD/YYYY.
« Reply #23 on: February 28, 2018, 04:31:45 PM »
is that liberals or Liberals ?
Or libourals?  :)
Offline mikeyw64
  • Country: wales
« Reply #24 on: February 28, 2018, 04:39:31 PM »
This is an interesting read
http://www.todayifoundout.com/index.php/2014/10/americans-write-dates-differently-practically-everyone-else-relates-data-storage-holy-wars-soft-boiled-eggs/
Extract:
Although we find it normal, our month-first arrangement to the rest of the world makes little sense, being what one commentator has called middle-endian (computer speak for bass-ackwards).
Endian refers to the organization of binary data storage whereby the most significant byte (8-bit unit of data) is typically stored first (in the smallest address, on the left) or last (in the largest address, on the right). If stored first, it is referred to as “big endian” and last, it is called little-endian.
When it comes to bytes of numbers, the first (left) digit is usually the most significant and will have the greatest value (e.g., if you had a numeric number 1,234, the “1” represents 1000 – by far the largest value in the number). This is the same with dates, where the year, which represents 12 months and 365 days, has the greatest “value,” and the day, the lowest.
In putting dates into bytes, in the big-endian format it would be written as YYYY/MM/DD, while in the little-endian format, it would read DD/MM/YYYY. By putting the month first, we’ve screwed this orderly system up by putting the middle value on an end (middle-endian) – and annoyed a large portion of the planet in the process.
« Reply #25 on: February 28, 2018, 04:43:25 PM »
Actually, now that you mention it, either one works here. I think I would tend toward 'take' but using 'have' would not raise any eyebrows.
TMI referring to the last reference.  ;)
what about "have" & "take"
eg I would probably use.
"I'm going to have a bath" or "I'm going to have a nap"
I believe the Americans are more likely  to use
"I'm going to take a bath" or "I'm going to take a nap"
That said I'm more likely to say "I'm going to take a dump" then "I'm going to have a dump"
« Reply #26 on: February 28, 2018, 04:49:01 PM »
The YYYY/MM/DD thing is understandable to me but only if used in that fashion; the first time I ran into it, the year was shortened to two numbers as in YY/MM/DD and I was a while figuring out what the hell was going on. Neither the American nor the western European methods seemed to work correctly.
On a slightly different note, 7:00 o'clock only happens one per day in Germany too and our AM/PM system confuses them as well as our date notation. Then again, their clocks confuse me as well.
« Reply #27 on: February 28, 2018, 04:52:23 PM »
I think it is bizarre that Brits have such a huge aversion to the letter "Z" (that is Zeeeee, not Zed!!!) while holding on to all those extra "u"'s.  I mean, "-ize" is one of the most purposeful use of Z, and without it, there isn't much left, well maybe "-zation"
categorize your colors
normalize your flavorings
sexualize that humor
industrialize your armor production
compartmentalize that behavior
Of course, English is a pretty insane language, anyway.  At least it is very descriptive, rich, and colorful.
« Reply #28 on: February 28, 2018, 08:12:06 PM »
I pronounce 'been' as 'bean'.  Gave my friends in high school (US) lots of mirth.  I pronounce 'herb' as 'herb' not 'erb'.  Words I picked up early as a kid in England.
« Reply #29 on: February 28, 2018, 08:32:59 PM »
... when they really wanted frankincense ... OK, gold.
Offline Rick Hall
  • Eruption
« Reply #30 on: March 01, 2018, 02:29:58 AM »
Bangers and Mash.
Perfectly understandable.
Oh, and "take the jug handle" in NJ, which is also crystal clear to this bloke from CO.
Rotary, traffic circle, roundabout, .... dafuk.
Rick
Offline mikeyw64
  • Country: wales
« Reply #31 on: March 01, 2018, 02:34:29 AM »
Bangers and Mash.
Rick
Mythbusters tested this a while back and proved that the roundabout was more efficient than the 4 way stop junction and better than a Policeman on duty
Roundabouts win with 460 vehicles going through the intersection during the 15 minutes.  All way stop signs had 385 vehicles go through in the 15 minutes and the traffic cop had 289 vehicles go through.  Roundabouts also have a safety advantage with less severe crashes.
http://www.mikeontraffic.com/4-way-stop-vs-roundabout/
Offline Rick Hall
  • Eruption
« Reply #32 on: March 01, 2018, 03:01:21 AM »
Mythbusters tested this a while back and proved that the roundabout was more efficient than the 4 way stop junction and better than a Policeman on duty...
I was referring to the different naming conventions as you travel USA ;)
I have no doubt they are efficient, I've driven in EU! :)
In USA, you'll run into several types at a roundabout/rotary/circle/island.
1) Those that are petrified of a rotary (10%)
   1a) Those that have no idea what lane markings are for. (10%)
2) Those that drive what many of us call "Big Dick Flash-mobiles", who are so large/rich they think rules don't apply to them. (10%)
3) Drivers that think they're the only ones on the road. See #2.
4) Normal drivers that know what a rotary is, and how to merge into one (70%)
Rick
Offline mikeyw64
  • Country: wales
« Reply #33 on: March 01, 2018, 03:31:29 AM »
Rick
ahhhhh got you :)
Hmmm wonder what the 70% would make of the "magic roundabours"
https://www.wired.com/2016/08/brilliant-sorcery-englands-7-circle-magic-roundabout/
« Reply #34 on: March 01, 2018, 05:32:52 AM »
Wow, I was born near there!
« Reply #35 on: March 01, 2018, 06:39:44 AM »
ahhhhh got you :)
I don't know about that 7 circle insanity but we do see more and more roundabouts here in the US. They are definitely way better than a 4 way stop and in many cases better than a light IMO.
« Reply #36 on: March 01, 2018, 07:00:45 AM »
Yeah, well the Dutch love the things (BTW- Americans usually call them rotaries but 'roundabout' is gaining ground apparently). In The Netherlands, one can see 3,4 sometimes even 6 or 7 different rotaries standing in one place!
They claim it is the only way to have cross traffic flow without having to interrupt either road with an actual stop. And I guess that is true enough, at least in theory. They are showing up more and more here in the Northeast US and while they may eventually be efficient, right now the two wrecked cars and the LEO cruiser with all  the flashing lights really slows traffic down to a crawl. :-(
« Reply #37 on: March 01, 2018, 09:57:18 AM »
I've always called them roundabouts.  Never called them rotaries.
« Reply #38 on: March 01, 2018, 10:20:31 AM »
You may be a bit optimistic in some of those numbers, I'd put #4 around 50% and adjust the others up a bit.
 :yikes:  :o :o :o   ???  at least 90%.
« Reply #39 on: March 01, 2018, 01:27:04 PM »
Yeah but you say 'whilst' too, which is not even a word so.....
I think a lot of the US calls them roundabouts also but here in beautiful, downtown New England we calls 'em rotaries. But hey, we measure our mileage in furlongs per hogshead too so it might be us that is off on this one.
