Finally got around to installing the 4 green led's in the dash and the 1 in the clock today. Had to take lots of stuff off as I was replacing the tired stock front brake lines with a Galfer 2-line set so it was a perfect time to tear into it. I'm very pleased with the improvement in visibility with the green bulbs, not too bright but very visible now. BTW: The Galfer 2-line system was a snap to install and makes the front brake a 2-finger affair each and every time with no lack of stopping power as with the stock "soft" rubber lines. Thanks again foe everybody's 2 cents on this topic. Mike in TX
