The C-14, aka Kawasaki Concours-14, the new one :) => The Bike - C14/GTR 1400 => Topic started by: SkylineNZ on May 13, 2011, 08:27:55 AM
Probably pretty silly, but I can't find a good answer anywhere. I'm swapping the OEM tires out before a long trip. I'd like to make the tire change happen at a local honda dealership (it's much closer to me and I hate the local Kawasaki shop).
Anybody know if they need to reset the TPMS sensor with a new tire install? I'm planning on reusing the existing TPMS sensors, it's a 2010.
No. Just make them aware that they are inside the wheels on the valve stems. As long as they do not hit and damage them, nothing else will be required. They should work find one your new tires are aired up and on the bike. Of course you may have to ride a short distance down the street to get the sensors to wake up and send info again to display on the dash panel.
Awesome - thanks for the quick reply. Time to take a trip to the shop.
+1...
I had my PR3's put on at a non-Kawi dealer because the $ was right, no problem as long as they're aware of the TPS and careful...
They should be used to doing tires with tps units inside, since many Goldwings have that option also.
Definitely tell them you have sensors... I was not specific about it this morning and the local Honda shop broke one. Which means, if I'm reading the other threads correctly, that I'll have to take the bike over to the Kawa shop after I get the tires reinstalled (brought in the wheels, I'll be damned if I let a shop touch my bike for anything other than warranty work) to have them link up the new TPMS sensor with the ECU. Yay.
No issues to report with the tire change - the Honda shop swapped the tires, TPMS worked just fine afterwards.
As an aside, I went to program a 2010 spare (credit card/wallet) fob this afternoon at a Kawasaki shop. The tech was nice enough to let me watch/help navigate through the KDS 3 software. The tire pressure sensor programming is definitely on the main screen.
