No, worries, bbroj, thanks for the complement.
You are absolutely correct that wiring aux fuse blocks is simple with just a litttle thought. Doing some internet searching for pages about automotive relays and 12 volt circuits/wiring should get a person up to a basic understanding of the concepts.
However (and an answer to Tele130's second question), one common mis-conception specific to the Connie C-10 is that by wiring an aux block or aux load directly to the battery, a user is not increasing the load on the J-Box.
That is incorrect. ALL loads to charge the battery (or carry a battery-connected aux load such as lights and heated gear) are routed through the J-Box and the main fuse and relay in the J-Box, no matter how they are connected to the bike. Don't worry about it, folks have logged millions of miles on Connies with lots of aux loads. If you ever have a J-Box problem, you deal with that when it arises.
It is not possible to avoid that fact
unless the alternator connections to the bike electrical system are substantially re-wired. I've never seen that done with a stock alternator - it is usually done in conjunction with the ZZR alternator upgrade. Credit where due:
Slybones' web site has some of the best explanation on this topic. My alternator wiring is a variation of one of his schematics.
Tele130, to your first question .... IMHO the alleged "plug-and-play" aux fuse block solution is only simpler to the extent that the included instructions are thorough, explicit and specific to your machine's wiring. I've not seen Murph's kit so can't comment about it. The FuzeBlock brand instructions are good but are not specific to the Connie and require some basic grasp of 12 volt wiring concepts. The FuzeBlock is simple in that the relay is integrated and the unit gives a choice of switched or un-switched on any circuit without re-wiring. Some may (rightly) argue that the integrated relay does not lend to easy replacement if it fails.
As in most engineering, the is no absolute one-best-answer ... finding the best compromises for your case is the trick
