Hi Guys- I picked up a screw in my tire a few weeks ago, and tried my emergency tire plug kit. I used my mini compressor that plugs into the accessory socket and it worked great!! This was my first time using a plug and I just love the way it turned out, and I could track the tire pressure while riding.
I have a 108 km (65 mile) commute each way to work and I'm having second thoughts on changing it right away. I've put 1000 km on it since the repair. Because the tire pressure can be continually monitored, and I doubt it would deflate instantly, I'm having a tough time throwing away a tire thats only half (11000km) worn at best. It's supposed to be a temporary fix, but it is working too well to throw in the towel, even though the new tire is in the garage waiting to be mounted.
It does add another level of risk, but ridng a motorcycle isnt exactly playing it safe anyway.
Anyone else experience this dilema? How far did you go on it? Mat
I've used a number of tire plugs over the years and I have NEVER had one fail on me. I know some like to spread around myth, in my opinion generated by tire manufacturers and others who make money from selling and replacing tires, and others cry "Doom and Despair" if you ride on a plugged tire.
Use you own judgement. If the tire is damaged and the cords cut, then replace it as soon as you can. If it's a nail or a screw (the most common thing in my experience) then a plug will outlast the tire. Done properly it's nearly impossible to get the plug into the tire. Add some cement to the mix and there is no way they will ever come out.
My opinion, others have differing ones. Decide for yourself and your situation.
