Maybe it is something else?
I went back through all the valves again, put enough bike back together and tried to give it a go. It started but I killed it in less then 5-10 secs because the noise was still there. I tried it once more with coils pulled so it would start and the noise is more like metal hitting metal in the area of cyl 3-4. Pulled it all apart again, pulled the plugs, left the valve cover off and turned it over and it was quite as ever. Lightly put the plugs in, no cover, and the noise is back. So that rules out hitting the valve cover but what else should I go after?
When checking the valves I had each lob facing up, screw driver in place and the feeler with some, but not heavy friction. I am using the .07 for the intake (ones towards the air cleaner I hope) and .08 for the exhaust. So, what in the hell am I screwing up? Should I do the adjustmets with nothing but the feeler so that I am not pushing down on the thing even slightly?
I can't belive this is driving me so crazy after all the other stuff that I have done on cars and bikes. HLEP!!!!!!!!
