The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: F-106 on June 06, 2011, 04:54:57 PM
Before I buy i just want to make sure I got this right. If you put a E-3 wing size tire { 13/70/18} it need to be bias to fit the 3" rim. Correct? THANKS
13/70/18 ?
Yuk! Why make a sports car handle like a dump truck is beyond me. I think you mean 130/70/18.
Bump.
Correct. A 130/70 radial is meant to mount to a 3.5" rim, the bias will fit a 3" rim. Here's Dunlop's fitment info:
E3 bias
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=86 (http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=86)
E3 radial
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=91 (http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=91)
Thanks Gary!
E3 bias
E3 radial
The sports car as you call it only sees the freeway. The only turns I go through are on off ramps.
Bump.
No curves??!! That's really too bad. :(
