Author Topic: Air filter  (Read 2093 times)
Offline Somerset
Air filter
« on: May 18, 2012, 08:26:27 PM »
Did anybody try to put individual conical type air filter on a connie 10. It would be easier to remove and reinstall the carbs.
and maybe a better air flow.
Thank's   André
Offline snarf
Re: Air filter
« Reply #1 on: May 18, 2012, 09:38:49 PM »
It has been tried but you will never get the bike to run 'right'
2002 Conc
1986 Conc "The spirit of COG"
Offline Mettler1
Re: Air filter
« Reply #2 on: May 18, 2012, 11:47:55 PM »
  Actually the Concours has too much airflow hence the 2 minute mod from SiSF which cuts the excess airflow but does need new jets to match the airflow.
   Look here;    http://sites.google.com/site/shoodabenengineering/
   also use search  either  2MM or 2 minute mod  for more info.
Offline jim_de_hunter
Re: Air filter
« Reply #3 on: May 19, 2012, 10:42:50 AM »
Expect to rejet the carbs if you go with individual filters for each one.  You'll end up with different jets in each carbs because the airflow will not be the same for each with individual filters.
2006 ZG1000 "The Blue Monster"
Offline Daytona_Mike
Re: Air filter
« Reply #4 on: May 19, 2012, 12:06:04 PM »
Thank's   André
Sure, many have tried, few with success.
 Dont do it unless you want your bike to run worse.
Offline Somerset
Re: Air filter
« Reply #5 on: May 19, 2012, 07:46:31 PM »
Thank's for the input, it will remain with the airbox.
André
