The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: EddieCap84 on March 30, 2024, 03:42:48 PM
Recently purchased bike and it's been perfect. Today for the first time I did some hard acceleration on the highway and took an off ramp, when I stopped at the red light a plume of smoke surrounded me briefly so I looked around and the lower left side of the bike was covered in oil including my foot. It still ran and operated perfectly on the short ride home after. I had somewhere to be so I frustratingly parked it in the garage and left it. I did do some quick looking around and can't tell where it's coming from. Any ideas on the matter guys?
You will have to find it yourself after cleaning. Sounds like that will be easy to pin point,
Hello
Plastic covers and hoof must already be removed.
Could this be it? What is it btw and how do I fix it
Yup, the camchain tensioner has blown it's bolt out. Plenty of oil comes out of there.
Replace the tensioner with a cheap manual tensioner from Amazon or Ebay for about $50.
https://www.ebay.com/itm/364759553484
Wow. How does that happen?
Metal fatigue, old age...any number of things. First time I've heard of that though.
So, I'm going to throw a manual tensioner in it. No big deal. But .. next question... What oil do I refill it with? Preferably something from AutoZone.
There is still thread in there and it looks like it might be a helicoil.
Get someone you can trust to check it out.
Do you know how to set the tension on the manual unit? Too tight and you can burn up the chain guides. Don't forget that you'll also need the gasket, 11009-1858.
Me, I do with a mechanic’s stethoscope, I start to tender by screwing by hand without forcing then, I refine not to hear any clicking, at 2000 rpm. ;)
(https://img.over-blog-kiwi.com/2/19/07/00/20191011/ob_921419_20191002-092822.jpg#width=1600&height=900)
