Author Topic: Speaking of odd car problems....  (Read 6384 times)
Re: Speaking of odd car problems....
« Reply #20 on: January 10, 2014, 12:18:53 PM »
Quick update: Not sure how long the problem has been going on but the 15 minute max. run time IS working on the system so normally this quirk would not even be noticed. My wife normally drives the car for more than 15 minutes anyway and so the remote start unit disengages along the way without anyone noticing (how would anyone notice that?); it only shows up if the car us manually shut down using the key when less than 15 minutes have passed since being remote started in the first place.
This morning however that other problem of the car not starting via remote cropped up again. That had been fixed and fully quite some weeks ago. This is another factor that leads me to believe there is something wrong with the remote starter / alarm control unit. Technically speaking..... is broke. :-(
Now off to see if I can get a modern unit to fit where the old version is so the actual install is easy.
« Reply #21 on: January 10, 2014, 02:07:50 PM »
Throw a KiPass fob in the trunk, problems solved  ;D
« Reply #22 on: January 10, 2014, 02:12:24 PM »
Are you using 'trunk' as some kind of euphemism there?
« Reply #23 on: January 10, 2014, 02:23:22 PM »
wow what model of car you drivin' to come up with such an analogy  :D
Offline blue14
« Reply #24 on: January 10, 2014, 02:24:26 PM »
Maybe you need a rock and with a well aim.........never mind!  Wrong vehicle
2010 C14, 2007 ZX14,  2004 KTM 300SXC
« Reply #25 on: January 10, 2014, 02:30:20 PM »
I was thinking of what the average Floridian might mean by 'trunk'. And don't forget- I've dined with you and saw the way you were looking at Mr. Elkhoof!
« Reply #26 on: January 10, 2014, 02:31:32 PM »
Maybe. Nothing says 'elegant' like beating on a vehicle with a rock....
Offline datsaxman@hotmail.com
« Reply #27 on: January 10, 2014, 02:41:20 PM »
Right...Neanderthals hit the car with a rock.
Use a hammer, and you are a Mechanic.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
« Reply #28 on: January 10, 2014, 03:32:12 PM »
I'm a little bit Neanderthal, between 2% and 4% it seems. :-) See sig. line for my ethnic origins, or so they tell me.  ;)
But on a more serious note, unfortunately I think hammers are the most abused of all tools. They are absolutely necessary and a fine tool but I think they are the ones most misused. Well, maybe hammers and pipe wrenches.  :rotflmao:
saxman
« Reply #29 on: January 10, 2014, 04:40:59 PM »
saxman
Someone mention Maxwell?
