Already done by the end of 2011:
SISF 2MM
SISF overflow tubes
SISF exhaust cam sprocket
Progressive fork springs/15w fork oil
For 2012:
ZZR1200 shock (done two weeks ago)
Make a bracket for my $15 water resistant smartphone mount (for Pandora and GPS)
Pelican topcase w/custom mount
Throttle lock
Resistor for the fuel gauge (I might end up using a potentiometer)
Other than that, I think it's just going to be fixing the little niggles that need attention:
New right side mirror (current one has a flat lens in it
New clutch slave cylinder (current one has a slow leak)
New clock (current one doesn't work)
New right side grab handle (bungee hook broke off the current one in a "parking incident" in Tennessee)
Straighten the front and rear subframes from said parking incident
To be clear, I did not drop the bike. I had it on the centerstand on an asphalt driveway at a cabin we were renting. The right leg of the centerstand sunk into the asphalt and the bike fell over against the supports for the deck.
