The C10, aka Kawasaki Concours - The Original => Accessories and Modifications - C10 => Topic started by: F-106 on January 01, 2012, 12:36:23 PM
Ok guys, what is on the list for 2012 fo the C10? I will go first. Get the bag lids and truck painted, SS brake lines, colormatch rifle base, tipoverbars. Hope the wife does not find out
(http://vrcc.photostash.com/vrcc_22432/bike%2012.jpg)
My wish list is huge, but takes a back seat to the most important planned farkle of 2012 - A trip to the National!
I have a bunch of farkles from my 86 that need to go on the 01. I am going to get Murphs extra fuse block, move my HID light over, install my stick coils, install cruise (have issues to figure out first, install Steve's ex cam sprocket and move my 2 min mod over. Send bowls in to get tubes installed, and get some new heated grips. Oh, need to decide if I am going to keep the new Givi on or go with my rifle base and homebrewed shield.
Wayne
She's getting a heated home. Starting to insulate the garage and putting heat in it just for her. She's also going to get a tune up and new brakes as soon as the garage is done. :)
Heli bars once I get them back from being powder coated. A trip to the National is already planned and reserved. The rest is more maintenacse than farkles. I may cut the fork springs and add PVC spacers and go with 10 weight oil. I really want to get myself into an MSF experienced course...
Install cartridge emulators (already purchased)
Install new float needle's in carbs (already purchased)
Install 1800 lummin LED driving lights to back-up my HID headlight (already purchased)
Install my Jim Snyder modified front left brake caliper on my rear brakes (already purchased)
And figure out how to mount and use my iphone for driving directions (gps) and music.
Install Stick-Coils and Wiring Harness as well as a Heavy Duty Shift Linkage from T Cro.....
Oh snap I am T Cro so l've already done these upgrades.
Sounds like it's up to you then.
C-14 engine! And a frame to match ;)
Purt near done farkling though. Race-Tech emulators, Progressive rear shock, EBC rotors (stock fitment size), Murphs heated grips, Murphs Hella upgrade light, Murph's PnP fuse block, SiSF's advance sprocket (his cam is on shelf waiting for the 'right' time). Bought a new helmet and boots last year, new leathers two years before, gloves every other year.
GPS would be nice, but I know most all the roads in CO, and paper maps work just fine for the few distance trips I do.
A/C would be way kewl, so would a chrome cup holder. But hey, it's a motorcycle ;)
Rick
My Mother always said, " If wishes were horses, beggars would ride." ::)
I wish for these farkles.....
replace h3 auxillary lights with LEDS.
To have Steve is Sunny FLA redo the carbs.
Mesh riding gear.
Some of that evaporative clothing that you wet and wear to keep me cool in the summer.
New clear nolan face shield.
Some easier method to stay hydrated while riding, such as a camel back.
Front Discs ..so exit stage right....used even.....
Oh and one very important thing....$$$$$$$$$$$$$$ so these things can happen. :)
And a new battery
Why is it all the best minds go into advertising these days...
I wonder if someone could do you up a .GIF of that thought process?
All my 05 ever needs is gas and an oil change. I would like some auxillary lights as my night vision ain't what it used to be. 8)
The main 2012 project is to install a much larger number in the odometer window on the dash.
My wished-for farkles are all routes and destinations (retirement is good).
:thumbs:
Install 17" rear wheel (from modified Mean Streak)
New front & rear tires (I hate the metzler 880's)
Upgrade the front rotors to 320 (if I can find a set of Caliper Adaptors) & Stainless Steal lines.
Murphs fork brace (shimmed)
Upgrade front forks with Race Tech Emulators.
Have bowl drains installed & Carb work from Steve in Sunny Florida.
Install taller windshield.
Install C-14 Rear shock
Replace L. mirror, L. Antler & L. Saddle Bag along with rear fender.
Install 3M black reflective tape (Shows up reflective white when headlights hit it) on saddle bag and rear fender.
Perform all the rountine maintenance while holed up for the winter
Replace front side reflectors with LED lights
Add driving lights up front
Replace rear lighting with LED lights, adding additonal lights
Ride more
+1 on a trip to Eureka Springs
not much farkling needed, I do need to get some Cree's mounted to backup the HID. Also want to ride more, The national sounds like a good place to start - steve
Having bought one of everything from Murph and TCro, I am going to buy one of everything from SISF - carb work and cams for certain, still on the fence about the 7th gear.
Already done by the end of 2011:
SISF 2MM
SISF overflow tubes
SISF exhaust cam sprocket
Progressive fork springs/15w fork oil
For 2012:
ZZR1200 shock (done two weeks ago)
Make a bracket for my $15 water resistant smartphone mount (for Pandora and GPS)
Pelican topcase w/custom mount
Throttle lock
Resistor for the fuel gauge (I might end up using a potentiometer)
Other than that, I think it's just going to be fixing the little niggles that need attention:
New right side mirror (current one has a flat lens in it ::))
New clutch slave cylinder (current one has a slow leak)
New clock (current one doesn't work)
New right side grab handle (bungee hook broke off the current one in a "parking incident" in Tennessee)
Straighten the front and rear subframes from said parking incident
To be clear, I did not drop the bike. I had it on the centerstand on an asphalt driveway at a cabin we were renting. The right leg of the centerstand sunk into the asphalt and the bike fell over against the supports for the deck. :o
Finish 4 into 1 exhaust system,
followed by; 2 minute Jett Kit, and change cam timing.
Some of these things mentioned aren't technically farkles, but I will follow along. I want to finish up designing and installing a dash shelf and even install a stereo system. I also want to install the oiled bushings for the rear set. I would also like to have a new seat cover installed and maybe even have it Spencerized. I also want to put in new fork springs and install a couple of drain plugs. I would also like to at least take apart my carbs and do an ultrasonic cleaning.
Install the risers I bought off fleabay
Knee savers
Fork Springs
Tipover bars
I do have my bike for sale (to please the wife, it's a long story) but it ain't selling too well.
