« Reply #5 on: December 14, 2017, 08:05:21 PM »
Yeah, there is that whole "dew point" thing. When you hit it, and it is humid outside, anything colder than the air will be pretty wet, quickly. Ventilation does help (it helps to equalize the temp and also helps with evaporation). Of course, ideally, it would be air-tight, which would stop the humidity, but that isn't realistic... or temperature controlled, but that is expensive. Some people try to opt for air-tight (as much as possible) and then use large buckets of desiccant (like silica gel) to try and capture what moisture does get in. But, again, kinda expensive and a hassle (since you have to "recharge" the desiccant regularly).
https://www.amazon.com/Silica-Desiccant-Beads-Blue-Indicating/dp/B01M0LL9WS
Logged
