Overall commentary on the digital display:
Current MPG: Entertainment value - good for fighting boredom. Information value - can be useful for hypermiling and finding optimal gear or w/s position.
Average MPG: EV - low. IV - good for comparing fuels, riding conditions & styles. Usually inaccurate vs actual calculations.
Range: EV - moderate. IV - nil, the range is calculated based on Current MPG and fluctuates wildly. It quits once you hit reserve. It would be useful if it recorded miles ridden after reserve was reached, but that would be too logical and useful.
Tire Pressure: EV - nil. IV - high, is a reminder when the tires need aired up. As far as emergencies go, the constant display is not required, as the warning will pop up when pressure drops below set level (32psi IIRC).
Ambient Temp: EV - good. IV - good. Useful info to help fight hypothermia and dehydration. Very useful when temps approach freezing to be more wary of icing.
The Red Light: Still way too bright. (Partially cover it with a stick-on dot.)
Fuel gauge: Okay - but not as linear as it s/b.
Coolant Temp: A digital display would be much better.
All in all, the display is much more useful on the newer models because of the ease of switching. Poor layout - more info s/b displayed on a single page, with fewer pages.
