The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: kzz1king on January 27, 2012, 01:46:55 PM
I am going to check my fuel levels. When I put my 2 minute mod in I used something other than das but cannot remember what. Got the idea here though. Anyone know? Thanks
Wayne
might ask Bubba Steve, but he and I use gas,,,,
you need something with the correct specific gravity, close to gasolene
I suggested once to use IsoHeet or Heet drygas additive, because it is safer, and also won't require cleaning the carbs afterwards.
I don't like mineral spirits, to me it's a contaminant.
jmho
Thanks, not sure what it was and I thought I heard it from Steve but I have a memory only a mother could trust. Gas has a specific gravity of .739 and alcohol has .802. What I don't know is if that is close enough. Just hate to mess with gas in the shop during the winter with the furnace and all.
Wayne
SISF IIRC does use something other gas to set float levels, just cant recal what it is
I would agree. I seem to recall him posting that he used mineral spirits. I did a search but did not comeup with anything. It was probably before the Crash of 2011. Perhaps he will see this and set us straight.
I'll send him a note...he should be along shortly.... ;)
I use de-scented mineral spirits with tcw3 oil in it for color. No issues on contamination, because I check levels on a dedicated test stand, then blow the carbs out with compressed air before the ship or get installed. HTH, Steve
Mammas and Pappas did a song about that called "This is Dedicated to the Carbs I Love"
Thank you gentlemen, now to find some tcw3.
Wayne
Walmart is were I get mine.
+1 on Walmart Super Tech TCW-3 Gal. When I bought mine 18 mos. ago it was around $12
Thanks guys, Walmart it is. Some of you add a teaspoon of the stuff every fillup?
If I run 200+ miles before a fillup I add about 2 ounces. 100+ 1 ounce. I found some cheap cough syrup bottle that fit in the right fairing pocket for trips. Bottle goes in a ziplock bag in case of a leak. That could be messy!! If you miss a fillup or two, no problem. My bike parked at home always has a full tank of gas.
If I run 200+ miles before a fillup I add about 2 ounces. 100+ 1 ounce. ...If you miss a fillup or two, no problem. My bike parked at home always has a full tank of gas.
I can see doing this for storage, long term, but if you ride regularly, and cycle fuel thru constantly, it's kinda silly no? Occasional use, maybe, but every fillup?
I mean adding 2 oz of oil to 6 gallons of fuel, is basically running a 2 cycle premix in a 4 cycle engine...
Just saying, and I am sure anyone following you on the road appreciates the aroma. ;D
But But BUT that's what Steve does right? ;)
Damn straight, Mister!! ;D
I'm sure they do! I use a great deodorant. 8)
THIS will absolutely put an end to all discussion about the use of TCW-3 in our ethonal fueled carburated Concours!! ::) Read this:
http://hhrchevyfamily.19.forumer.com/a/using-2cycle-oil-in-gas-wal-mart-tc-w3_post7688.html (http://hhrchevyfamily.19.forumer.com/a/using-2cycle-oil-in-gas-wal-mart-tc-w3_post7688.html)
In my next feature I will end ALL oil thread discussions!!!!!
If I'm on a trip, tank over tank, I'm not running tcw3. But my bike is a "recreational vehicle" so it sits alot, and when it's sitting it has TCW3 in it. One time last year I expected to be riding, and didn't spike the tank; then the bike set in the hot shop during the summer and suffered severe dehydration (evaporation). end result, pilot circuits clogged, and I had to pull the carbs tho clear the pilot circuits. i've always kept TCW3 in the voyager, same carbs, and it has never had an issue. Steve
My question; I run ethanol free gas in everything possible, having a choice of three local stations that sell it. The only exception is when I may be out of the area and need fuel. Is there any benefit to adding tcw3 to this fuel?
One of the reasons I started using TCW-3 is I had a "jerkiness" for yrs when crusing at about 35mph in suburban streets even after a good carb cleaning, Steve's 2MM and T Cro's Stick Coils. So I did a compression check and had 3 cyls at 190 psi and #2 cyl at 170 psi. A teaspoon of oil in that cyl bought the pressure upto 185 psi. Looked like a ring problem.
Talked to "guru" Steve and he suggested maybe a stuck ring due to carbon. He suggested using TCW-3 might remove carbon and free up the ring. So after using it for about 3 months one day I noticed the "jerkiness" was gone. Did a compresssion test and all cyls were back to normal psi.
The claim is that it removes-reduces carbon. Really don't know for sure but I like the results in a smoother running bike.
OH NO! I inadvertently started an oil thread. New ground for me.
Wayne
Wayne
Gee Wayne, I don't think it was intentional. We will just pretend it didn't happen. :deadhorse: :deadhorse: :deadhorse: ;D
