The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: Tele130 on May 31, 2013, 07:37:34 AM
I know I posted this before but being mentally challenged,................ I have a hard time finding my way home from work let alone a post I made 5 months ago ??? ;).
What size of wrenches/sockets do I need? Front and rear.
Thanks. ;D
Front Wheel Removal
Axle clamp (pinch) bolts 8 mm Allen
Axle 12 mm Allen
Brake caliper mounting 12 mm
Rear Wheel Removal Muffler mounting bolts
12 mm
Rear axle nut 27 mm
Brake caliper mounting 8 mm Allen
Final drive removal 14 mm
Thanks Chris. :chugbeer:
Any time 8)
....Rear axle nut 27 mm
Or a 1-1/16" SAE will work..... ;) same size....and you might already have one.... ;)
Thanks MOB. I'll check. My Connie is buried in the garage somewhere.............My two sons moved back home for the summer (school break) and all their "Stuff" is in there. Not sure I'll get any saddle time this season. :o
Also, depending on the front tire you are removing or installing, a 12mm to remove the front fender bolts.
For the front axle, you can use a metric bolt head if you don't have the proper size allen wrench. Double nut it.
Years ago I bought a 12mm socket style wrench and the allen part was long enough that I just cut a section off the end to use in the other side and I carry that in my tool kit.
Good point. When I installed my "GT'S" I found that if I inflate the tire to seat the bead and then deflate it, I could install it without removing the fender. Those bolts on the INSIDE of the fender are a PITA! ???
