The C10, aka Kawasaki Concours - The Original => Accessories and Modifications - C10 => Topic started by: Wild Rose on December 26, 2011, 03:55:27 PM
Is there much differance in swapping the c-14 rear shocky to the zzr1200 shocky changeover?
Is there any real differance in the make up of the shockies?
Leo
C-14 is taller than zzr. C-14 is more plush riding and compliant than zzr. C-14 is rebuildable, I don't know about zzr.
The C14 shock is much longer than the stock C10 shock and is also longer than the ZZR shock and unless you are really a leggy SOB your going to need to also find a Lowering Rocker to go with the install.
The mounting bolts used on the C14 shock are smaller than the C10/ZZR shock by some 2 mm; the lower mounting fork on the shock is easy to drill out so that you can use the lower mounting bolt and spacer (?) from the ZZR. Most who have done the C14 shock install have simply used the smaller upper mounting bolt through the frame mount with nothing more than a flat washer on each side of the nut & bolt; this works fine. Both have the same style of remotely mounted adjustment reservoir so that requires only figuring out where you want to mount it at and at best an L type of mounting bracket.
I can vouch that the ZZR shock is night & day better than the C10 shock and I'm told that the C14 shock is night & day better than the ZZR shock.
Tee's correct, the c-14 is as much better than the zzr shock as the zzr shock is better than the c-10 shock. BTDT. steve
I'm guessing that the C14 shock remote adjustments are
preload to adjust ride height when weight is added
and rebound damping
Is that correct?
As a matter of curiosity, what does a C14 weigh compared to a C10?
I just did the C14 rear shock conversion a short time ago and I don't know if I would feel safe drilling out the lower mounting fork on the C14 shock to work with the bolt from the C10. The width of the C14 lower mounting fork is smaller than the C10 shock and on the side you would have to drill out the larger hole for the C10 bolt it won't leave you with very much material left on the sides of the hole.
I chose to have a custom bushing made and use the nut and bolt from the C14. The bushing is the same I.D. and length as the C14 bushing, with the O.D. being the size of the C10 bolt.
Here's the link to how mine went http://forum.cog-online.org/index.php/topic,27617.0.html (http://forum.cog-online.org/index.php/topic,27617.0.html)
.... and I don't know if I would feel safe drilling out the lower mounting fork on the C14 shock to work with the bolt from the C10. The width of the C14 lower mounting fork is smaller than the C10 shock and on the side you would have to drill out the larger hole for the C10 bolt it won't leave you with very much material left on the sides of the hole.
And that's why I said to use the bolt and spacer from a ZZR shock not the shoulder bolt as used on the C10......
I also have a C14 shock ready for install, Have not found any of Norms lowering rockers. I am concerned about the extra ride height. I am thinking about making my own lowering rocker, Is there a template available as for the hole locations. I am thinking about tracing out the stock rocker and moving the shock hole in the rocker down to adjust for the extra length of the shock. Would this be correct? I may install the shock and see how it is, I know the kick stand may be a little short with the heigth increase. ???
Not to rain on anyone's parade here but it would be unfair to Norm to ask someone to template his design without asking first.
T Cro; I totally Agree, I appreciate everything you & other members have done to improve the Concours.
P.S. Your coil stick upgrade is working great.
Thanks, Jeff
Thanks, Jeff
Thank you two times over.
BTW while searching for lowering rockers, 1 1/8" is the magic number here. I went more because I'm short and we drag peg alot. This puts you about 1/2" up over stock.
