The C-14, aka Kawasaki Concours-14, the new one :) => The Bike - C14/GTR 1400 => Topic started by: Scaffolder on May 03, 2013, 05:16:20 PM
I just threw 3,000 miles on my new 2011 C-14. The brakes started pulsating at about 1200-1400 miles. They became unbearable at 2500. I brought it to the dealer at 2800 miles and the dealer confirmed the warped rotors.
The manager mentioned a new service bulletin for the C-14s braking system. So when she looked it up it was only for law enforcement vehicles. Maybe they know something that we don't. So that didn't help matters any. The parts are ordered and will have it fixed when they come in.
My 2008 had warped rotors at around 10,000 miles and were fixed under warranty at around 15,000 miles. Brake pads lasted 40,000 miles. My 2010 had warped rotors at around 30,000 miles and were fixed under warranty at around 38,000, but with a bit of a fight. Now my 2011 has warped rotors at under 1,500 miles. The mechanic said I might want to change the brake pads while they are doing the rotors. I told him this is a brand new bike and they can put them on under warranty too. He didn't know it was that the bike was this new. Something is messed up with the braking system design. It is time for Kawasaki to figure out what they are doing wrong. I love everything about these bikes except the brakes.
34,000 on my 10 and brakes and rotors are fine (knock, knock, knock...).
- fine here too.
- i turn the bobbins holding the discs every 2/3 weeks or so.
- fine here too.
I am at 6500 on my 2011 and have no noticeable warpage.
I have never touched those. I also have not seen any recommendation about doing so in the manuals or on the forums... Is this something other people are doing?
I never had a warped rotor on any other bike. Seems strange.
Have you noticed side to side uneven pad wear?
16k on my 08 and so far so good, of course I run galfer pads if that makes a difference?
I didn't notice anything but the warping. During the first 3000 miles I plan on just doing gas and motor oil and gear oil.
Maybe Kawasaki should run Galfer pads.
When I was at the dealer I even had to look at the new Honda Streetglide. The side bags are so small. They don't even hold a full face helmet.
Any clue on what's on the service bulletin?
Is it possible that you've been coming to stops from high speeds and then holding the brakes on such as you might at a stop light on an incline? I'm wondering if it's possible that while the rest of the rotor cooled the area under the pads stayed relatively hot causing the rotor to cool unevenly and then warping?
I, too, have always believed that the driver might have some factor in the warping situation.
If I have to stop in the situation as I described above I've always made it a habit, on the bike or in the cage, to make sure that I have a lil room between me and the car in front of me so that I can release the brakes and roll a bit so that the hot spots under the pads can cool like the rest of the rotors.
I did not get any info from her about the service bulletin. I am hoping someone on this forum might have some insight.
I have always made it a habit of good braking distances and not slamming the binders on. And never hold the brake on after stopping.
I don't think so. You'd have to ride outside of your subdivision in order to fully test those pads... :P
Say it ain't so, Max. Say it ain't so! Oh the humanity! :yikes:
You ONLY got 16,000 miles on a 08 ??? you need to get off the puter and go for a RIDE
Oh yeah you live in OHIO ... is it STILL snowing ???
I often just use the right middle finger ( yeah that one) on the front brake , maybe my XXL hands are the reason I only need one finger but warped rotors on the new bikes ? I thought that problem was resolve ? I try not to use the brakes.
Hi guys! New guys here, just outside Detroit, MI--the Motor City.
I was a volunteer motor officer (motorcycle cop) for the 2007-2012 seasons, and it's standard practice for us to ride hours without ever putting a right foot down--you put your left foot down at lights, because the right is standing on your brake. (You also are never in neutral while riding--ever--in case you need to get outta the way fast!) Holding the brake leaves your lights on, and prevents rolling around.
My point is,... I'm riding my '12 Kawi now like I rode my Harley, left-down at lights/right on brake, and after 400 miles on this new bike, I now have a rear brake squeak, and the pulsing other folks are describing while braking. I also believe the brakes are very 'grabby' at a certain point after initially not providing much force at all, like they suddenly jump in force, but... that's another story.
Did they seriously do such a poor job picking discs for this bike that they're wearing out/warping this fast? I mean, if you can warp a rotor just sitting at a light because 'that part of the rotor isn't cooling as fast,'... someone FAILED, miserably.
Anyway,... consider my '12 possibly afflicted too. There's not much else to complain about, but that's certainly one thing.
PMC
PMC
"volunteer motor officer"? As in you did this without being paid?
"Did they seriously do such a poor job picking discs for this bike that they're wearing out/warping this fast? I mean, if you can warp a rotor just sitting at a light because 'that part of the rotor isn't cooling as fast,'... someone FAILED, miserably."
I was speculating, I don't know this for sure.
Welcome aboard PMC!
PMC
I do the same foot thing as I was taught that in the MSF class that I took many years ago. One of the few things that stuck. Well, actually a lot of things stuck. I don't use neutral either at stops and watch the mirrors continuously as I'm extremely paranoid and psychotic. I also use both front and rear brakes when slowing.
The pulsing is from the front rotors. First time I've heard of squeak from the rear. I'd check for a mouse stuck in the mechanism. I'm sure your maintenance is up to date but there's recall on the rear brake actuating lever. Make sure that fix has been installed, though I don't think it has anything to do with the squeak.
We're hearing more reports on the 12's having rotor issues on the fronts. I don't much care for this turn of events as I'd thought that Kwak Central had worked out the kinks in the rotors. They've certainly had enough time to do so as it's been ongoing since 2007. These rotors were also on the ZX-14. They've had the same issues that we've had.
As to Kwak failing miserably in fixing this, you've certainly got my vote on that one.
Welcome to the forum! We've got a thread stickied for the C14 Police bike conversion. If you have the time, you may want to glance at it.
http://www.zggtr.org/index.php?topic=95.0 (http://www.zggtr.org/index.php?topic=95.0)
PMC
This sounds exactly like my bike. I like to hold my right foot on the brake lever, but since I've owned the linked brakes models, I've been trying to adapt different techniques so I don't make K-ACT mad. Or K-TRAC.
I love these bikes and this is still the only problem I have with them. I sure do hope I don't have to get 3 sets of rotors to each set of tires. It will really limit the miles I get to put on this year.
Oh I ran it real hard yesterday you smart arse....... but 262 miles of barely getting on the brakes, cause I know how to gear down before the nasty twisty bits instead of using the brakes. ;)
:D
Hi all/Conrad! Thanks for the warm welcome.
Strange... I just took a ~20 mile ride for gas and lunch, and didn't particularly notice any brake issues this time. :-\
Temporary Thread Departure: Yup, lots of our local departments in the area run reserves/auxiliary officers. Sheriffs in Michigan--from way back in the day--have always been allowed to deputize willing and able folks. Since most here also go the extra mile to TRAIN, and realize the benefit of extra help for special events (and yes, it's free), we have some really great teams. I was a marine officer (on the lake) from 2000 to '07, but once I did motor in '07, I never looked back. I just switched departments this year, sold the Harley (which I paid for, and used) and now I'm happily on a better bike while driving another department's patrol cars :) Everyone wins :)
Being a former motor officer, though, my choices for "next bikes" was extremely limited... and mine's coming along nicely, brake complaints or not :)
(http://imageshack.us/a/img15/2199/20130428155837771.jpg) (http://imageshack.us/photo/my-images/15/20130428155837771.jpg/)
Ooooh, we love that :) I will help
In Virginia a sheriff is just an officer for the court- they only manage the jail and courtroom security, and serve summons/warrants and such :) They have nothing to do with the police, tickets, law enforcement, etc. Of course, we also don't place our cities inside counties either.... plus we are not even a state (we are a "Commonwealth")!
Wrongo, my friend. That may be in your locality but for the vast majority of counties in VA they serve summons/warrants and such, issue citations, provide law enforcement, and pull drunks off the road just like any other LEO would do. My nephew is a deputy in Mecklenburg county and does all of these things.
However, in the city of Fredericksburg they function similarly to what you state.
Well, it has been that place everywhere I have been (lived/worked/frequented/noticed) so far (Richmond, Chesterfield, Henrico, Newport News, Norfolk, Virginia Beach, Portsmouth, Chesapeake, Suffolk, Alexandria, Williamsburg, Charlottesville, etc). Mostly cities though. Granted, that leaves a LOT of other territory- especially west. Guess I am guilty of the dreaded "ass u me"!!!! Send the Police- I mean the Sheriff!! :)
Go west, young man, go west, or north for that matter....
I started doing this also when I first heard of the rotor issue, probably back in late 07 or early 08. 100,000 miles and no brake problems.
I have 12,500 on my '08 ( just bought it last year with only 2,000 mi. on it) and haven't had any issues with the stock front brakes other than a squeak that has recently started just before stopping. I do engine brake a lot so maybe that is the difference. That may shorten tire life, but it also needs less braking pressure.
> 73,000 on my '10, no warpage but worn THIN AS ALL :censored:
I'm hard on brakes :D
Not that hard!! Mine only lasted 40000 miles ;D ;D
I do wonder as to why some never warp, yet a few last without issue?? It appears to be luck of the draw and I am surprised that the Gen 2s are exhibiting the same issues. With the carrier change and pad composite change you would think things would be fixed, but apparently not. I'm still happy with the EBC rotors and pads.
My 2011 really blows my mind. Just because it is so new. I'll change brand of rotors and pads, but Kawasaki should be paying for it.
I am still hoping to find someone in the forum that rides a law enforcement C-14 to see if they Know what the fix was for.
You and me both! In fact, I'll buy dinner for the one that comes through with it...Seriously....don't read the fine print, though. ;)
Caveat....dinner is at McDonald's using the value menu...
