The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: Furbo on August 22, 2016, 04:29:01 AM
Well, yeah, like the title says, at the end of the 'official riding season' (end of Nov) my beloved Babyshitbeigebeauty will have between 65-70 on the clock. I generally do the maintenance on it over the winter; valves, oil, fork seals, plugs, etc, as its a good way to stay in the garage with a pipe & boursom and outta SWMBO's way in the house! ;D
Anything I should check on particularly? Thinking to flush the radiator and replace hoses...but...what say y'all.
Pearl beige luster 2005 was one of my favorite colors.
Steering stem bearing check/adjust perhaps?
Etc might cover more things than most would think about. Check and/or grease all bearings?
Your starter/alternator chain is most likely near it's wear limit. Also consider this mod to your chain tensioner as they have a tendency to flop into the clutch hub.
http://s240.photobucket.com/user/vk5zlr/media/chain4.jpg.html (http://s240.photobucket.com/user/vk5zlr/media/chain4.jpg.html)
I made my own out of a pipe nipple and a bit of time with grinder.
I had to replace my tensioner as it got a bit bent from banging into the clutch.
Good Luck
Alternator chain.....yeah. That's good, thanks.
I replaced the cam chain tensioner with an aftermarket manual kit years ago. Wow - hadn't realized how much noise it was making!
