As Jim said, there is not an adjustment on this clutch. The clutch is painfully difficult to bleed though so it is entirely possible there is still air in the system even after pushing a pint of brake fluid through it.
Also, take off the clutch lever and clean and lube the pivot points and the sides of the lever where they move inside the lever housing. The pivots tend to get dry and act very poorly without ever being noticed by the rider.
If it isn't one of the above, it is probably time for the master cylinder, the slave cylinder or both to be inspected. My slave cylinder was replaced under warranty when it began to act erratically but I do not remember the mileage on the bike at the time. It was fairly high though, maybe 40K miles.
Guys,
Is there anyway to adjust the clutch on the c14 other than bleeding the line.
I have tried bleeding the line and that doesn't seem to change things at all.
My clutch doesn't engage until the lever is about 80% to the handle bar or starts dis-engaing about 20% out from the handle bar.
The lever adjustment is in the 1 position which is the most aggressive position.
Any suggestions appreciated!
later,
C-14 Pilot
