Audio not synched' with the Video? The bane of my digital existence! Drives me nuts and apparently I am the only one who notices it. Mine is not related to satellite TV though but the problem jumps across all / any digital formats I use.
The solution is to delay the audio which can usually be done in a digital TV. The problem with mine (Samsung) is that I have to call up a menu, then a sub- menu, then the time delay bar and shift it one way or the other and see if the synch. got better or worse. Takes a while to dial in, and the next thing I watch is out- of- synch. anyway. And in the middle of this annoying fix, I have to listen to 'the others' who complain and ask why I 'cannot just watch the show'. !! 'Cause it is like watching a dubbed version of a Japanese horror movie, that's why!
What I really need is a dial so that I can advance / retard the audio from the current point to where it is correct. They are kinda', sorta' available but prohibitively expensive and besides, I have enough things wired together to make a 'television'.
OK, off holiday rant now.
<snip>
but somtimes it isn't synched to the broadcast, so it sounds like you are in an empty concert hall, with echos...mehhh
