I've met folks who like to play" how far can I coast downhill". Generally with the engine off.
While you may have had no choice, it's a very bad thing to do to your transmission as the gears are force-fed engine oil from the oil pump and with a bike that's rolling in neutral with no oil the secondary or output shaft is still turning relative to road speed.
Fretka
Because of your turbo conversion I formed a sort of prejudice about you, and it is as follows: you know what you're talking about. That being said, 2 points:
1. I'm not one of those folks. I don't play with the bike downhill or such because in the event of an unknown, I want to have all the capabilities of the bike (braking or accelerating) to complete the jurney alive
As you said, I just didn't have a choice (as it turned out).
2. I don't think it's that bad. I designed transmissions (F1) and, although I'm not into tribology, I know three things brake the oil film on the tooth and bearings, leading to metal-to-metal contact: torque (or force), speed and temperature.
- There is only enough torque transmitted from the wheel to the gearbox to overcome internal frictions up to the clutch. It's not little, but it's not much, probably less than 10 Nm, 80% of which is actually used to move the bevel gear, which is in its own casing with its own oil.
- I was coasting at not more than 20 or 30 mph, and only for about 2 miles. The speed of the secondary shaft was therefore not high, and it was free to rotate inside the gearwheels.
- Regarding temperature, it was cold weather and the bike was fine, so that wasn't an issue.
