Author Topic: Lowering Links  (Read 3428 times)
Offline Gitbox
Lowering Links
« on: August 22, 2013, 07:07:52 AM »
Has anyone ever used these?
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
2000 Kawasaki Concours ZG-1000 (sold)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: Lowering Links
« Reply #1 on: August 23, 2013, 06:05:54 PM »
robin - got the pm but i'll answer here. These straight links won't work if you want to keep your centerstand. Personally I'd never give mine up. As far as the c-14 vs the zzr shock, the c-14 is the better of the two, but will require using a lowering link. the zzr will raise the rear of the bike about 1/2" so that's doable. The other option - the progressive 465 - is a really nice shock too, and won't require a lowering link or any other mods to install, just a little more $$$$. HTH, Steve
Offline Gitbox
Re: Lowering Links
« Reply #2 on: August 24, 2013, 04:17:36 PM »
Thanks Steve.
Wow, I never even thought about the center stand and yeah, I want to keep mine too.
Offline Gitbox
Re: Lowering Links
« Reply #3 on: August 24, 2013, 04:25:21 PM »
I don't have my rear suspension apart right now. If I did I would not have to risk ridicule with the following question:
Regarding lowering the bottom shock mount, after looking at the parts diagram, would it be possible just to flip over the unitrak arm?
Offline T Cro ®
Re: Lowering Links
« Reply #4 on: August 24, 2013, 07:22:43 PM »
That would alter the height of the bike a LOT the lowering link made by Norm was only just a little different than stock and it lowered the bike by a couple inches.
« Last Edit: August 25, 2013, 01:38:15 PM by T Cro ® »
Tony P. Crochet
Re: Lowering Links
« Reply #5 on: August 25, 2013, 11:00:18 AM »
That would lower the bike a LOT the lowering link made by Norm was only just a little different than stock and it lowered the bike by a couple inches.
The link / bone pivot point is actually below the line of axis from the shock to the frame, flipping the link would raise the bike higher using stock bones.
IIRC Norms links only moved the hole about 1/4" to 5/8" lower off axis line (he made 3 versions)
The ratio he had was about a 5:1, meaning 1/4 lower made the bike 1-1/4 lower
Offline T Cro ®
Re: Lowering Links
« Reply #6 on: August 25, 2013, 01:39:41 PM »
Thanks for the correction MOB I see now that I was backwards in looking at the picture
Tony P. Crochet
Offline jim snyder
Re: Lowering Links
« Reply #7 on: August 25, 2013, 03:50:09 PM »
What we need is a friend with a CNC machine so we can make the stuff we need for our old dinosaur bikes.
Offline Nosmo
Re: Lowering Links
« Reply #8 on: August 25, 2013, 08:27:48 PM »
What, you mean like this stuff?
http://geekologie.com/2010/10/do-want-this-dinosaur-bones-mo.php  :o
Offline jim snyder
Re: Lowering Links
« Reply #9 on: August 26, 2013, 02:39:08 PM »
No, no, no, that was just a figure of speech. Our dinosaurs bikes are still on the road and going when some much younger and more expensive ones are in the boneyard.
